Sponsored by:
Sponsored by:
bulb light on Dashboard
Old 07-09-2014, 04:35 PM
buddahzigzag's Avatar
Default bulb light on Dashboard
ok i changed the daytime running bulb in the front headlight assembly..how come the light bulg symbol is still popping up?
are you suppose to reset it?
2007 Audi A8L...
Old 07-09-2014, 05:15 PM
Mike141's Avatar
No, it should just go off in its own. If you press the check button is it showing you where on the car the light is out? Do you have access to a VCDS, I'd use that if all my lights are in and the error is still coming up.
Old 07-10-2014, 02:43 AM
Yes I have VCDS...What Check button are you referring to? And what procedures to do in VCDS?
Old 07-10-2014, 04:39 AM
Mike141's Avatar
There is a button on dash panel near instrument cluster that reads "CHECK". If you press that a picture of the car should come up in center display as if a door was open and whatever light is out will be shown by a red line....at least that's what my 07 did when I had a parking light out. You can run a full scan on VCDS or check under central electronics module (I think?).
Old 07-10-2014, 08:55 AM
ok thx.I will try...will let u know the results..
Old 07-10-2014, 07:56 PM
It seems the last couple of days the bulb light been coming on then going off by itself..idk..maybe it will stay off for good..keep u posted
Jbones68
10
07-14-2021 01:03 AM
landsmarra
01-28-2006 03:56 AM
nadrealista
01-26-2006 01:04 PM
VOLKAUDI
Audi 100 / A6 (C4 Platform)
05-20-2005 08:53 AM
speedracerrc
06-22-2003 08:24 AM
Quick Reply: bulb light on Dashboard
