Serious run problems with the 4.2
#12
Thanks again Mishar, we discovered the same while replacing the relay, new relay did not help so on to the pump. I will check the board here for information on replacing it, as well as what parts aside from the pump I should be replacing.
#13
Problem resolved, replaced the passenger side pump. Not too difficult either, other than the lighting and the cramped space forward in the trunk area. Took about 2 hours, I did not hurry at all as I did not want to be opening the tanks up again. Ran through the readiness tests, everything is green no issue, no engine codes remain. Thanks to everyone for pointing me in the right direction on this one.
Andy@Ross-Tech
VAG-COM Discussion
10
07-09-2015 02:24 PM
magallcg
07-06-2007 08:52 PM
gcarnutt
03-21-2007 09:37 PM
Beaverific
13
11-15-2006 08:18 PM
