Specific AMI cable 2008 A8L to iPhone 4
Hello and thanks in advance. This forum helped me decide on a certain vehicle previously and I'm looking for the cherry answer on top of my D3 sundae.
Flew into Salt Lake City Tuesday morning and arrived back in NY before 9am Thursday. Great test drive for my new to me, previously well-pampered A8L. Only thing missing was the music from the iPhone 4 which I had meticulously prepared for the 2000 mile celebration. When I connected the supplied AMI cable to the phone and switched the CD/Aux via the MMI, I got message "No Device Connected." iPhone apparently not recognized; no charging, no lossless music. Please note, the iPhone isn't for calls and is dedicated as a music storage accessory only. Any assistance, procedurally or hardware (cable specifics) would be appreciated. Have previously seen a post re the cable and connections but unable to locate it. The cars exceeds my expectations but the iPhone music is burning a hole in my pocket. Thanks to the community in general!
The "L" cable is an AMI to Lightning connector. The OP said he has an iPhone 4 which has the older 30 pin connector. I'm thinking he needs the 4F0 051 510 K with the red grommet and 30 pin connector.
If the phone doesn't charge, your AMI is not connected
or powered correctly. I took my son's iPhone 4 to the car, plugged it in, the charging signal came up right away, the music played automatically regardless of his passcode wasn't entered. Unless you have the power to the iPhone, the cable or the AMI wasn't turned ON or Broken (which I doubt).
-AMI will connect and charge iPod mini (6GB), iPhone 3 (8GB), iPhone 4 (8GB), iPod touch 4 (32GB) - Tested.
-<a href="https://www.audiworld.com/forums/a8-s8-d3-platform-discussion-60/play-music-iphones-android-phones-wirelessly-2881790/">AMI will connect to the right Bluetooth dongle</a> to stream music from iPhone 6 and Android Phones.
Cheers,
Louis
Cheers,
Louis
Your reference doesn't sound right to me from the audiusaparts listing, nor from the picture on their site. The K cable is the one that works in my Q5 without art if I use 30 pin IIRC. L superseded E, which is where the D3 started. Even though "L" comes later than "K", in this case its an older design back to "E." Lightning cable would be like an AC if it even worked in a D3.
Here is the site listing specific to OP's 2008 A8 that gets back to the "L" spec. Audi Wholesale OEM Parts - Audi Genuine Accessories - AudiUSAParts.com e-Store I don't know that you can even use a Lightning cable in a D3; I know my Q5 Lightning one doesn't cross over/work in my D3. Easy just to use an adapter though.
Advice nets to the big picture advice I suggested--call them, give them your VIN and cable spec (30 pin iPhone/iPod), and go from there.
You're right. I was confusing the new 30 pin "L" cable with the "AL" cable which is the latest lightning cable that replaced the AC and AD lightning cables (which were both short lived).
I'm glad to see that Audi is replacing the overpriced and confusing array of AMI cables in the newest models with a much simpler USB connection in the center console. The 2016 C7 uses this and initial reports indicate it's fully MMI integrated with Apple and Android and maybe other makes of phones.
AMI 30 pins cable 2008 Q7
I don't know if the 08 A8 AMI uses different cable, but I think the best is to unplug and replug the cable to see if the cable was loose. Next is to check the power behind the AMI box. Since the MMI can see the AMI option, the MOST bus and CAN should be OK.
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
Should be either a discontinued E or a newer L. Red or blue bands around it would not be a good thing IIRC, color coding of newer ones.
I just recently bought a replacement cable for my 09 A8L. (car did not come with one) I bought the cable from Amazon with no issues. I tossed in an old iPod generation 3 to just leave in the car.
http://smile.amazon.com/gp/product/B...ilpage_o06_s00
behnam
03-28-2018 06:26 AM
KBLOVE
Q7 MK 1 Discussion
08-03-2010 04:06 PM
