start access
start access
Hello fellow Audi lovers. Just purchased an 04 A8l for a little bit of nothing. Car won't start or anything else actually. I talked to dealer before purchasing vehicle and they said prior owner had car diagnosed by them. He was told start access module and a repair quote of a little over 2k. After countless hours of research I believe it's the start access as well. Now after purchasing vehicle and bringing it to them they now say they don't want to touch the car. They said replacing the access module would require changing steering column as well. $1,200 for module and $1,700 for steering column then another $1,500 in labor. The kicker is even if I wanted them to do it they said the last time car was in (when it was first diagnosed with faulty access module 9 months ago) carpet was wet. Sooooo wet carpet means some "main harness in floor PROBABLY could have water damage resulting in ALL modules being subject to water damage in the future" so they won't do repair. Sound accurate?? Will be towing car home this week. Ordered diagnostic software and it should be here by the time the car gets here. As of now all I know is it will not start. Only lower dash lights.....gear selector, mileage, etc light up. Dome lights work, key in ignition reminder beeps and doors lock and unlock with remote. Nothing else. Going to do testing this week once I get car home.
Get a read out when you get your vcds and post it and someone will steer you in the right direction.
If the EEPROM is readable you may may be able to do a cheap fix.
See my previous posts.
A lot of Audi dealers have got no idea and want big markups on new modules.
See online price for j518 kessy from Jim Ellis Audi
Regards Graham
Regards Graham
Regards Graham
Regards Graham
Ok good luck
I have a couple of spare new mossfets and transistors here after my botched attempt at replacing them. If anyone wants them for the postage price.
Don't think it's the A version as it does not have the advanced key option.
That's what's the mossfets are a part of.
You should be able to see the version number on your vcd readout.
I had to keep clearing the error codes from my kessy to get the advanced key to work.
Ok good luck
Had to clearing codes aerials short to plus.
My kessy worked but the advanced key part did not work properly and was getting worse.
Cleared the codes and would work for a bit.
The mossfets are just for the advanced key nothing to do with your car not starting.
The A version kessy does not have the two mossfets or the transistors near them.
I will get a photo of if I get a chance.
Try plan C
Try plan C
Try plan C
Try plan C
Sorry my bad
It was the plain 4e0909131 see photo. The circuit board has all
the places for mossfets etc.
This one is cloned and starts my car but no advanced key.
Anyway get the carprog and exact same kessy and should be all good.
Just looking on eBay USA lots of the A models out there some sub $100
Actually two ways you can go
Carprog and clone or my new best friend in Poland who has online vas account and is a real wiz charges about 45 euro plus you need a vas 5054A clone about $130
