Sponsored by:
Sponsored by:
Suspension Air Leak Troubleshooting
Old 09-10-2011, 11:51 AM
  #11
williebone's Avatar
Benpitt, since the Front is Dropped Down to the Bump Stops you more than likely will not get a Floor Jack to Clear. You may need to get a Few 2x4s for each side and Double Stack in a Staggered 6" Step Up and forget about Ramps (Nose too Low). You should be able to get a Floor Jack under the car at that point. My Tech couldn't even clear their Lift when this happened to me and luckily we had access to a few 2x4s. Keep us posted and good luck. Laters,
P.S. I was fortunate enough to have access to a Lift when we made the Repair. It is much easier to Raise and Lower the Car at will during removal and installation. So if you are doing the Wrenching then it's going to one hell of a job to do on your back.
Old 09-11-2011, 08:28 AM
  #12
benpitt's Avatar
Here's where I am. I jumped the compressor yesterday and it ran smooth. Sprayed soapy water around the air resevoir, air lines and control valve with the compressor running and didn't see any leaks/bubbles. Replaced the relay with one from the dealer (correct part 4H0-951-253-A). Plugged new relay in and everything worked as it should. I was able to activate lift and all 4 wheels pumped up. I put everything back together and lowered the car off of the jacks and now it's back to the fully lowered front position and compressor is shut down? The rear of the car appears to be at a normal ride height.
At this point I'm ready to take it to the dealer, pay for an hour of labor for the diagnosis and then replace the parts myself. I'm guessing one of two things are in play here: (1)the compressor is pulling too much juice and burning out the relay and/or (2) there's a leak somewhere in front air lines/struts.
I'd rather pay the dealer $120 for the hour to rule out a component at this point than pay $650 for a compressor and it not turn out to be the problem. Any last ditch ideas before I head to the dealer this week?
Williebone is right on the clearsance issue with the front fully slammed down you can't use the jack. I had to drive the car onto a couple of bricks, before I could use the factory jack. I put a floor jack under the control mount to subframe mount for security since I couldn't get the car high enough witht the factory jack to use my jack stands.
Thanks again for the replies!
Old 09-11-2011, 08:56 AM
  #13
Mister Bally's Avatar
If the compressor is defective (normal failure mode per WABCO is that one of the magnets detaches from the motor housing and drags against the armature. Detached magnet reduces motor output by 30-50%. When this happens the orange fuse should open. If there is an air system malfunction causing the motor to run for long periods of time, an internal sensor detects the overheat condition and shuts down the compressor circuit. I cannot speculate how or why the relay fails unless someone overfuses the compressor which is unlikely.
Old 09-11-2011, 09:40 AM
  #14
williebone's Avatar
My leak was a Faulty Control Valve Unit which is Located behind the Driver's Side Wheel in Wheel Well Liner. To get to that you'll have to remove the Wheel, and the Wheel Well Liner to access it, but it is an easy Repair. However, the lowest price would be at audiusaparts.com and is still an expensive part. I'll say that at this point going to Dealership for an Hour Diag is not a bad idea. I knew going into the Repair that my Techs said to Replace Compressor, Relay and Control Valve Unit from the Start. We completed the Repairs (Compressor & Control Valve) under 2 hours and did the Relay prior to the work. You are on the right track so keep us posted and good luck. Laters,
Old 09-14-2011, 07:05 AM
  #15
benpitt's Avatar
Just an update to everyone following the thread. My wife took the car to the dealer for diagnostic work and came back with an estimate for $6500. $5670.91 to replace the two air bag struts in front and control valve body. The other $800 was for upper control arm bushings (4), stabilizer link ends (2) and a new battery.
I spoke with the gentleman in Florida who rebuilds these air bag struts and he recommended replacing the control valve first and then work my way up to pulling the struts if that doesn't solve the problem. I'm suspicious to say the least that both front struts failed simultaneously with the control valve and will keep everyone updated.
I ordered the control valve and bushings from a site sponsor "www.AudiUSAParts.com" and should have them here by Friday. Just an FYI, $405 for the Control Valve from these guys versus $599 from my local dealer which was retail + 10%. The parts guy at AudiUSAParts was very helpful and I will be using them again!
Once I get the Control Valve replaced I can proceed with checking the struts and see where I go from there. I'm obviously hoping the struts are good but I've got nothing to lose at this point working in stages since I have other vehicles I can use while I wait on parts.
To be continued...
Old 09-14-2011, 07:20 AM
  #16
mishar's Avatar
I wouldn't expect anything less from a dealer.
Old 09-14-2011, 09:58 AM
  #17
williebone's Avatar
Out of all of the Posters on this Site, I've rarely seen anyone lose a Strut other than MB. What's most common is the 40amp Fuse, Relay, Control Valve & Compressor. When someone developes a leak in the system and a Fault Code they tend to think it's an Allroad Platfrom Issue and it is not. We don't have Bags so sliming a Strut doesn't work here and is not the culprit. The leaks develope at the Control Valve so when the Dealership quoted the cost, it was to cover themselves since they didn't know what to Replace. I haven't had any issues since I replaced the Control Valve which triggers Over Heating, then kills the Compressor and/or burns out the Relay. Net and +1 for this Board and our experiences which helps others make the correct move. Congrats and keep us posted! Laters,
Old 09-15-2011, 02:41 AM
  #18
AusA8's Avatar
You can add me as another strut failure mode. We replaced all of the items you've mentioned and it did not fix the issue. The last item was the strut. Replaced that and problem fixed...
Def. agree that this Board helps tremendously. I only wish that the Aus spec cars could use the US parts. They are sooooo cheap compared to Aust.! I think that this an area that I need to look into more. It just cost me $900 to replace a rear window regulator!!!
To the OP, I hope it turns out to be the control valve.
Old 11-06-2011, 07:56 AM
  #19
benpitt's Avatar
Default Success!
Everyone,
I just wanted to give you all an update on this repair for future reference when someone needs to go down this path. In the end it was the drivers side air strut.
It was a long process but I learned a lot about my car and found a good honest Audi mechanic in the Atlanta Georgia area (Ringtec) and another honest strut rebuilder in Pampano Beach Florida (Mercedes Master Tech).
Nalley Audi in Roswell Georgia initially diagnosed the car as needing 2 front struts, upper control arm bushings, battery, air ride valve body and sway bar end links for $6596.20. When I questioned their diagnosis I was told that the fault codes indicated the need for these repairs. I was assuming the sway bar end links and control arm bushings were visibly inspected. They did not indicate the need for the compressor.
After replacing the air ride control valve and bushings I sent my struts down to Mercedes Master Tech (ebay seller) to test my struts and rebuild as necessary. The passenger strut looked much newer than the driver side and I suspect it had already been replaced at some point. Jeffrey Limpert is the owner and advised me the drivers side needed rebuilding but the passenger side was good. Jeffrey sent the struts back to me and I installed them without success. The rebuilt one had a leak and needed to be sent back. Jeffrey was very open with me about being new to the Audi struts but assured me he could rebuild it properly. I was under some time constraints so I ended up getting a refund and buying OEM. Jeffrey was very honest during the entire process and refunded my money once I sent the strut back. He later followed up with me once he had identified the problem with the rebuild. I would not hesitate to use him in the future if/when the rear struts need rebuilding. The difference is $800 for rebuilt compared to approximately $1600 for OEM.
Paul at Ringtec in Roswell Georgia is another product of my journey. When I couldn't figure out where the problem was after my initial reinstall of the struts he found the leak and replaced the strut without trying to sell me additional services. The reviews speak for themselves on his expertise, honesty and integrity so I will definitely be going back to him for service in the future.
My total cost including the new compressor (ebay $607), one new strut, air ride valve body, new battery, 4 upper control arm bushings and sway bar end links was $3050.
I don't know if the valve body or compressor needed replacing in the end but based on my research on this board, as well as others, I felt their replacement was money well spent.
I hope this helps someone in the future but the bottom line here would be to find an honest Audi technician and don't settle for the shotgun replacement of parts as the answer.
The following 2 users liked this post by benpitt:
faisalfaisal (09-18-2022), Jrich1 (12-26-2021)
Old 11-07-2011, 01:27 AM
  #20
AusA8's Avatar
Glad to hear mate. The relief when you've sorted the problem is just great isn't it!!
Now you can get back to driving and enjoying her.
Cheers
Quick Reply: Suspension Air Leak Troubleshooting
