Sponsored by:
Sponsored by:
suspension problem. please help
Old 02-02-2014, 08:03 AM
  #31
dmum93's Avatar
so my brother in law is a used car dealer and his partner is a man of many talents. he took a look at my car yesterday and somehow fixed it without changing the strut. the right side was leaking. he injected fix a flat into the airbag, and did a bunch of other stuff i didn't understand. now obviously fix a flat isn't a perfect but i figure if it worked, why not. and if it didn't, i have to change the strut anyways. also for the level control pressure sensor, i was told you needed to change the entire compressor. how true is that?
Old 02-02-2014, 08:13 AM
  #32
mishar's Avatar
Fix Flat or Slime might work for some time but it might also create additional problems if it gets into system. Pressure sensor is part of the valve block.
Old 02-03-2014, 09:22 AM
  #33
03_AR_CO's Avatar
Big +1 here, a lot better off in the long run replacing a single air strut or pump than getting fix-flat throughout the air system. Too many good parts can go bad as the system vents through the valve block etc, not through the strut, thereby getting fix flat throughout the system. I had an allroad prior to the A8 and a number of allroad forum guys regretted the easy slime fix for their air suspension.
Old 02-05-2014, 06:44 PM
  #34
Banned
da9th_one's Avatar
Originally Posted by dmum93
Also, how much did that cost you? Just want a ball park amount
I had to replace the two front air struts/shocks whatever, not too long ago and it cost me a bit over $3700 for an indy shop to do it...rides like a dream again...
gpinkwater
17
09-01-2016 09:07 AM
NightBlue4.2
A6 (C7 Platform) Discussion
12
02-12-2016 03:19 PM
balabee
12-26-2015 08:23 AM
bigbruggsy
Audi allroad
10-04-2015 09:00 PM
KekePerkele
09-28-2015 09:29 AM
Quick Reply: suspension problem. please help
