Sponsored by:
Sponsored by:
Suspension stuck in Dynamic Mode, HELP!
Old 09-16-2014, 05:15 PM
Johnnyb2451's Avatar
Default Suspension stuck in Dynamic Mode, HELP!
Hi, my 2004 A8L with 148,000 miles is having an issue. The suspension is stuck in dynamic mode and the green low clearance suspension light is on with the arrow pointing down. The other suspension setting are greyed out. Please assist, I have read many, many threads on here and none speak of the exact issue I am having. My friend and I checked the fuses on the passenger side of car. All 4 shocks are level on lowest (sport dynamic) height. Car drives and rides fine. I have two good leads about what it maybe but want opinions please!
Old 09-16-2014, 11:16 PM
mishar's Avatar
It can be few things but VCDS scan would narrow it down. Compressor fuse (40 A) and the relay are behind the dashboard, just above drivers left foot. You have to take off that trim in order to get to them. Be careful there is an airbag. Besides that it can be compressor itself, one of level sensors, may be Valve Block or even Leveling Module. That's why I would start with scan. Otherwise it can be very expensive randomly replacing parts.
I hope your battery is good. Bad battery can make all kind of problems.
Old 09-17-2014, 04:24 AM
Mishar, thank you very much! We could not locate the 40 amp fuse yesterday. We only found the air suspension fuse which was 10 amp I believe on the passenger side fuse box. I just had the battery replaced at the dealership July 2013. I think it is okay, I will check the MMI to ensure it says 100%. I like my Audi so much after 4 years that I plan on keeping it indefinitely. I am seriously considering purchasing a VCDS. Where is the best place to buy one? Does anyone in Atlanta, GA have one to scan my car until I can buy one?
Old 09-17-2014, 06:42 AM
mishar's Avatar
Here it is.
Compressor fuse is behind the trim (crazy place for fuse) below the instrument cluster.
Old 09-17-2014, 07:58 AM
tjf
tjf's Avatar
You Definitely need to scan it. If the compressor overtemp fault occurs, it will not illuminate the yellow suspension light. ...You would think it should, but it doesn't.
You may be able to reset the fault and get it to run for a little bit, but chances are your compressor is going, or gone. The other settings are grayed out because the compressor will not run, so it can't lift to those heights.
Old 09-17-2014, 10:28 AM
Mishar, thank you. TJF, that really stumped me as to why the yellow suspension light was not coming on. I am concerned the front driver's side air spring (damper) may have caused that compressor to run too much because of a leak though I never saw the front left side down but maybe twice when it was below zero outside. Earlier this year, I slide into a curb and all components on the right front undercarriage had to be replaced including the air spring. I can't help but wonder if this made the left side go bad. The past month or so I noticed the driver's front side lifting up every time I was stopped but didnt think much of it because I never heard the compressor kick on when I was detailing my car (every weekend). From what I read on other threads, the compressor overtemp fault can occur due to a malfunction in the thermostat of the compressor? Very frustrating if a fail safe causes a problem. Anyway, a guy named Joe that lives near Atlanta contacted me and said he would scan my car this evening. I will post the codes later.
Old 09-17-2014, 05:29 PM
Here are the fault codes for the suspension system....
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 2541171FEC14DD36C75-8070
2 Faults Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 11100001
Fault Priority: 4
Fault Frequency: 67
Reset counter: 45
Mileage: 234271 km
Time Indication: 0
Date: 2014.08.14
Time: 14:50:22
01487 - System Function Test
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 236045 km
Time Indication: 0
Date: 2014.08.27
Time: 17:32:58
I will put the entire read out below.....
Wednesday,17,September,2014,18:00:49:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUML44E14N019796 License Plate: JOHN
Mileage: 238950km-148476mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E14N019796 Mileage: 238950km/148476miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Sporadic communication error 1000
38-Roof Electronics -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D0533634
Coding: 0007773
VCID: 1F4D05F7CE4807E68D9-804A
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - - Intermittent
16692 - Cylinder 8
P0308 - 002 - Misfire Detected - Intermittent
16690 - Cylinder 6
P0306 - 002 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0029644
Coding: 0000002
VCID: 24470A1BE72E243ED0B-8071
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224B0C03FD3A2A0EA27-8077
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0533634
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00171 - Key 1 not learned
Freeze Frame:
Fault Priority: 5
Fault Frequency: 0
Reset counter: 53
Mileage: 236016 km
Time Indication: 0
Date: 2014.08.27
Time: 12:19:42
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
VCID: 23450907E2202306A91-8076
2 Faults Found:
01876 - Belt Height Adjustment Button (E333); Up
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 5
Reset counter: 78
Mileage: 235460 km
Time Indication: 0
Date: 2014.08.20
Time: 11:31:37
01877 - Belt Height Adjustment Button (E333); Down
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 78
Mileage: 235460 km
Time Indication: 0
Date: 2014.08.20
Time: 11:31:37
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346BM047509505
Coding: 0000103
Shop #: WSC 03058 444 54540
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 301CG047535409
Subsystem 3 - Serial number: 7410.03.040000000000010115˙
Subsystem 4 - Serial number: 010115˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E
Component: KLIMAAUTOMAT 016 0240
Coding: 1085761
VCID: DABBF4E315EA22CE3A7
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0123113
VCID: 2C57E23B8FFEEC7E18B
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H40 0380
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Serial number: AUZ4Z7D8022207
Shop #: WSC 00000 000 00000
VCID: 29591B2F800CF956E3D-807C
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: E5C1D71F2C949D36875-80B0
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D1005677
Coding: 0016233
Shop #: WSC 07118 444 92441
VCID: DCB7F2FB1FDEDCFE28B-8089
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 03005041291483
Coding: FCFE7BDD1B2B04
VCID: 264310139112D62ECEF-8073
3 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 238910 km
Time Indication: 0
Date: 2014.09.17
Time: 13:10:22
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 238910 km
Time Indication: 0
Date: 2014.09.17
Time: 13:10:22
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 238815 km
Time Indication: 0
Date: 2014.09.16
Time: 19:01:37
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 0
Reset counter: 53
Mileage: 236016 km
Time Indication: 0
Date: 2014.08.27
Time: 12:19:42
Coding: 0015510
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 67
Reset counter: 45
Mileage: 234271 km
Time Indication: 0
Date: 2014.08.14
Time: 14:50:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 236045 km
Time Indication: 0
Date: 2014.08.27
Time: 17:32:58
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H43 0570
Revision: 00000000 Serial number: 355HW047545068
Shop #: WSC 07439 444 01029
VCID: 3561C75F5CB4ADB6775-8060
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H04 0090
Serial number: 00000614000001
Coding: 0003476
VCID: 1D313FFFC44415F69F5-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028428
Shop #: WSC 12336 024 394758
VCID: 204F060BF336381EB43-8075
2 Faults Found:
01482 - Motors for Central Locking
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 2
Fault Frequency: 0
Reset counter: 51
Mileage: 190160 km
Time Indication: 0
Date: 2003.10.08
Time: 00:37:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 83
Mileage: 238800 km
Time Indication: 0
Date: 2014.09.16
Time: 19:01:28
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040401280074
Coding: 0065086
VCID: 275D1D179618CF26F59-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 254
Reset counter: 85
Mileage: 190172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:20:11
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 83
Mileage: 238815 km
Time Indication: 0
Date: 2014.09.16
Time: 19:01:44
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000678362
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000032547
Coding: 0010111
VCID: 1E3338F3C9420EEE86F-804B
Subsystem 1 - Serial number: VK4978T0BKEE
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 83
Mileage: 238812 km
Time Indication: 0
Date: 2014.09.16
Time: 19:01:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
VCID: DEB3F8F309C2CEEE46F-808B
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 238800 km
Time Indication: 0
Date: 2014.09.16
Time: 19:01:28
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 09504 444 84390
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: E2CBCC033DBAEA0E627-80B7
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304BJ047560277
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000327700
Shop #: WSC 07439 444 53797
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 321008806B
Coding: 303030393135313035414B56413033323130303838303642
Shop #: WSC 07117 444 12393
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: DDB1FFFF04C4D5F65F5-8088
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 238800 km
Time Indication: 0
Date: 2014.09.16
Time: 19:01:28
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: DFCDC5F70EC8C7E64D9-808A
1 Fault Found:
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 64
Mileage: 237929 km
Time Indication: 0
Date: 2014.09.05
Time: 18:15:01
Freeze Frame:
Speed: 255.0 km/h
Temperature: 33.0°C
Error Code: 480
Pressure: 2.67 bar
Pressure: 2.72 bar
Pressure: 2.65 bar
Pressure: 2.52 bar
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 238800 km
Time Indication: 0
Date: 2014.09.16
Time: 19:01:28
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3008798
Coding: 0000005
VCID: E0CFC60B30B6F81E743-5000
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 08730402901613
Coding: 0001208
VCID: 2149030FF83C3116BBD-8074
End ---------------------------------------------------------------------
Old 09-17-2014, 08:56 PM
mishar's Avatar
You should check the fuse and the relay. Compressor doesn't look good but give it a chance if fuse or/and relay is broken.
Old 09-18-2014, 04:20 AM
Okay, I sure will. My friend is going to assist me after work, thank you!
Old 09-18-2014, 08:18 AM
tjf
tjf's Avatar
I'm going by experience. My compressor failed when going from normal height to Lift. I had the compressor overtemp fault. I never got the yellow suspension warning light. The "Lift" selection just grayed out. I was able to reset the fault...eventually. It took about 30 resets where it would trip after about 1 second. Then it ran fine, for a little while. Enough to get me home anyway. It faulted on overtemp again. I put a resistor across the temp sensor and it ran, for a little while. Then the compressor self destructed. That was over a year ago. I still have not found a significant shock leak. My car can sit for a month and not drop more than an inch in any corner.
Quick Reply: Suspension stuck in Dynamic Mode, HELP!
