Sponsored by:
Sponsored by:
04 Air Suspension Issue ( VCDS Error Codes Galore)!
Old 12-30-2013, 07:08 AM
mkeyfur's Avatar
Default 04 Air Suspension Issue ( VCDS Error Codes Galore)!
So I took my 04 A8L on a road trip to NJ for the first time in a year. Over the weekend, I experienced the following:
1) MMI screen stopped popping up without me manually pushing the cover (grinding after it reaches the open position of about 95%); and
2) Air suspension light (yellow) came on and stays on when driving. The dynamic light (green) began to flash on my return trip to the DC area.
I ran a VCDS scan and got a bunch of error codes, but I'm not sure what these codes really mean. I'm most concerned about the air suspension or anything else that is going to do long-term damage. Given the costs of parts (pluse my lack of mechanical know-how) and after reading a number of posts, I really don't want to be destined to give the dealer close to $6K for repairs (upper control arm bushings, air suspension pump with relay, front air springs).
Can anyone help on the following errors so that I can prioritize(FYI: want to keep this car for another 4 - 5 years) on what I should do next?
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: Mileage: 196980km/122397miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D1534273
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4D3899CEEED2E68D9-804A
3 Faults Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
18282 - Valve for Torque Support Mount
P1874 - 001 - Short to Plus
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224B316DFD9CFF0EA27-8077
1 Fault Found:
00526 - Brake Light Switch-F
011 - Open Circuit - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D1534273
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8BFD3856B40E5DE0C3-808D
Subsystem 1 - Part No: 4E0 905 852 C
Component: ELV 1734
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 195616 km
Time Indication: 0
Date: 2013.11.25
Time: 15:26:40
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 G HW: 4E1 955 113 B
Component: ILM Fahrer H12 0170
Coding: 0123113
VCID: 2C57DF558F58397E18B-8079
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
2 Faults Found:
01024 - Rain Sensor (G213)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 7
Reset counter: 141
Mileage: 195630 km
Time Indication: 0
Date: 2013.11.27
Time: 08:46:52
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 141
Mileage: 195630 km
Time Indication: 0
Date: 2013.11.27
Time: 08:46:52
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 24473775E788F13ED0B-8071
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 05005041311556
Coding: FCFE7BDD1B2B04
Shop #: WSC 40901 444 57504
VCID: 26432D7D91B4032ECEF-8073
1 Fault Found:
00384 - Optical Databus
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 141
Mileage: 195629 km
Time Indication: 0
Date: 2013.11.25
Time: 14:51:20
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV 1734
4E0905852C ELV 1734
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 195616 km
Time Indication: 0
Date: 2013.11.25
Time: 15:26:40
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 25412A71ECB20836C75-8070
5 Faults Found:
01400 - Suspension Level Control
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 5
Reset counter: 139
Mileage: 195629 km
Time Indication: 0
Date: 2013.11.25
Time: 13:50:03
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 141
Mileage: 195630 km
Time Indication: 0
Date: 2013.11.27
Time: 13:20:22
01487 - System Function Test
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 0 km
Time Indication: 0
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 18
Reset counter: 139
Mileage: 196155 km
Time Indication: 0
Date: 2013.12.19
Time: 07:21:18
01577 - Turn-Off due to Over-Temp
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 15
Reset counter: 179
Mileage: 196956 km
Time Indication: 0
Date: 2013.12.28
Time: 11:45:32
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H43 1100
Revision: 00000000 Serial number: 355HL047545003
Shop #: WSC 09111 444 84474
VCID: 387FF3054B0085DE6C3-806D
1 Fault Found:
02927 - DVD Read Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 4
Reset counter: 141
Mileage: 195474 km
Time Indication: 0
Date: 2013.11.20
Time: 06:52:45
Freeze Frame:
Hex Value: 0x5295
Hex Value: 0xEBAC
Hex Value: 0xFF01
Hex Value: 0x0000
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040402030053
Coding: 0065086
VCID: 275D207996BE1A26F59-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 179
Mileage: 195520 km
Time Indication: 0
Date: 2013.11.20
Time: 19:52:24
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000032591
Coding: 0010111
VCID: 1E33059DC9E4DBEE86F-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0BCYE
2 Faults Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 141
Mileage: 195628 km
Time Indication: 0
Date: 2013.11.27
Time: 08:46:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 179
Mileage: 196872 km
Time Indication: 0
Date: 2013.12.27
Time: 15:28:00
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000000020
Shop #: WSC 09101 444 00267
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1401160397
Coding: 303030393135313035414B56413031343031313630333937
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 184717 km
Time Indication: 0
Date: 2013.04.01
Time: 21:10:22
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 255
Mileage: 184717 km
Time Indication: 0
Date: 2013.04.01
Time: 21:19:16
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 12
Reset counter: 255
Mileage: 184717 km
Time Indication: 0
Date: 2013.04.01
Time: 21:19:26
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 184717 km
Time Indication: 0
Date: 2013.04.01
Time: 21:19:36
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 195629 km
Time Indication: 0
Date: 2013.11.25
Time: 14:46:36
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
Shop #: WSC 00000 785 00200
VCID: DFCDF8990E6E12E64D9-808A
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 95
Reset counter: 139
Mileage: 195630 km
Time Indication: 0
Date: 2013.11.27
Time: 13:20:38
Freeze Frame:
Speed: 0.0 km/h
Temperature: 4.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 173378 km
Time Indication: 0
Date: 2012.08.02
Time: 21:06:02
Freeze Frame:
Speed: 103.0 km/h
Temperature: 28.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3008786
Coding: 0000005
VCID: E0CFFB6530102D1E743-5124
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 08730402901697
Coding: 0001208
VCID: 21493E61F89AE416BBD-8074
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 141
Mileage: 195630 km
Time Indication: 0
Date: 2013.11.27
Time: 13:20:00
End ---------------------------------------------------------------------
hellonwheels33
32
04-16-2023 07:32 AM
jeffkruse
12-16-2021 05:59 PM
carl viking
36
04-27-2020 01:17 PM
Pmpsch
Q7 MKII Discussion
14
12-06-2015 01:14 PM
kevf95
Canadian Discussion
09-01-2015 04:34 PM
Quick Reply: 04 Air Suspension Issue ( VCDS Error Codes Galore)!
