Telephone microphone not working A8L
Just picked up a 2006 A8L with 73K on the clock. Look forward to the drive to work each day now. The car MMI system was not working when I first looked at the car but was repaired at the Audi dealer before purchase. from what I understand ouch to the price tag the shop I deal with paid to get it repaired. I still have one issue in that the Bluetooth phone connects and I can receive and place calls but No one can hear me. Looks like I have no microphone function.
Running SW: 4610.
Do not have the voice control option installed and button on wheel is inactive as expected and MMI is grayed out
I checked to see if the microphone was muted in the MMI and it is on.
Dealer said nothing they worked on to repair the MMI would have affected the microphone.
Could there be a coding issue turning off the microphone?
Can the VCDS detect a microphone issue?
Was Reading about some initial poor quality microphones used by the factory in with updated microphones now available Fact or Fiction?
If the microphone is dead is their a connector in the overhead panel or am I looking at removing a lot of trim?
I plan on getting the VCDS from Ross Tech as a few avoided trips to the dealer will easily pay for it.
Running SW: 4610.
I got a similar car, similar mileage but I checked everything before
I gave the owner the cashier check. I can fix car, but won't buy any car that has something NOT working, unless I don't really care about that something.
Nothing is wrong with the microphone in my 06 A8L. It works perfectly, people can hear me very well without any echoing from the cabin. When they fix your MMI, they didn't turn the Voice Activation back on. I don't think anything is wrong with your microphone, it's the people who accidentally screwed up the software.
Welcome to the forum and enjoy fixing the car... :-)
You should read how to pick up a nice and working car before picking up the car.
With Audi dealers and shops, the problems are always there before they touched the car and it's always your fault.
Cheers,
Louis
Cheers,
Louis
Check the coding
See this from Jake.
It's happened on other cars too, the info below is for reference only as we have not seen a post of your cars scan to see equipment levels etc and faults if any.
If you have ross tech vcds, scan the car and compare, or better yet post here.
If you don't gave VCDS take it to the dealer and get them to check the coding on the modules below.
From my old D3:
Code:
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 H HW: 4E0 035 729
Component: Interfacebox H43 2740
Revision: 00000000 Serial number: 346AR057519329
Coding: 0000003
Shop #: WSC 05146 444 64369
VCID: 2649FCB4E861
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
No fault code found.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000501210190
Shop #: WSC 12336 024 394758
VCID: 346D16FC2EBD
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H10 0700
Revision: 00000000 Serial number: 00000007512824
Coding: 0010900
Shop #: WSC 02313 785 00200
VCID: 244DE6BC9E5D
From my old D3:
Code:
Coding: 0000003
VCID: 2649FCB4E861
VCID: 346D16FC2EBD
Coding: 0010900
VCID: 244DE6BC9E5D
Banned
Hello JR2006,
As Louis stated, and I have seen myself every time when installing a replacement MMI Control Head, Gateway, or both, some items are removed from the "INSTALLED LIST", BECAUSE that MMI CH is from an other vehicle with other options, or the MMI CH is brand new and must be coded a certain way, that is why it is always best to copy said installed list and coding of MMI CH and Gateway, if the MMI is totally non functional then you must always go into the "INSTALLED LIST" and check the check boxes of the options of what you know you have in the vehicle.
BE SURE TO CHECK NUMBER 67 VOICE CONTROL.
NOTE: If you check something the vehicle does not have installed like I did "3D Special Vehicle Control Module", that said item will result in a fault, like in my "Gateway Fault", then just remove it.
I agree that this is a result of the install and the dealer should make it right.
See attached pics of installed list from my 05 W12, and an old scan of my coding of modules from 2012.
Johnny
Friday,29,June,2012,00:00:57:10074
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1F 25 28
34 36 37 38 3D 42 46 47 4F 52 53 55 56 57 61 62 65 67 69 72
76 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1F-Sat. Tuner -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
3D-Special Function -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 300IE037525206
Coding: 0010003
Shop #: WSC 00000 000 00000
VCID: 33611BFF2E11
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012351
VCID: E5C535A75045
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 F
Component: Gateway H10 0080
Revision: 10 Serial number: 180040540880FA
Coding: FFFEFFDD1B7D0E
VCID: 2759FFAFEAC9
Faults Found:
00380 - Special Vehicle Control Module (J608)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Revision: 00000000 Serial number: 00000504060047
VCID: 346318E32B1F
Johnny
Chassis Type: 4E0
76 77
Coding: 0010003
VCID: 33611BFF2E11
Coding: 0012351
VCID: E5C535A75045
VCID: 2759FFAFEAC9
Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
VCID: 346318E32B1F
Cheers,
Louis
Cheers,
Louis
Thanks for the help. A VCDS is in my future. I will post results after it comes in. I had already considered this as a needed item when I purchased the car.
I have 2 other minor trim items I agreed to fix and new about before purchase.
Any good suggestions for parts sources
Car restoration is a hobby and this car did not come home in boxes as some of my others have. Seems to be a great overall clean problem free car to to learn the Audi brand with while having a great ride.
Already started reading up on the timing belt change that will be due before next winter seems similar process to my VW 2002 Passat with 2.8L 6.
Just got my VCDS and ran the Auto Scan. posted below did not see anything obvious to change but new to this. Some other error codes showed up for (0F)digital radio and (47) sound system not coded correct error. Also (67) Voice control shows Component: SDS 3501 US H46 0630 not H45 as seen in other posts not sure if this means anything. Still no working Mic for the Phone. Could something be turned of in the hidden menu?
Saturday,18,April,2015,16:31:45:15695
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
Ross-Tech: Home
VIN: WAUML44EX6N022263 License Plate: 7ASRX7
Mileage: 121170km-75291mi Repair Order: 4-18-2015
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44EX6N022263 Mileage: 121170km-75291miles
01-Engine -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0F2787280
Coding: 0007773
VCID: AE1046D8392A8A514C3-80FB
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0080193
Coding: 0000002
VCID: A502B9F46CDCC909BD9-80F0
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: A208A2E87DF23E31D8B-80F7
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F2787280
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8FCC0006B2EA4E1F6F-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: A404A4F067E63001AA7-80F1
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Revision: 00000000 Serial number: 303EE067522360
Coding: 0000003
Shop #: WSC 08599 002 1048576
VCID: B22852A82D12AEB128B-80E7
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000003360
Subsystem 3 - Serial number: 0117.03.060000000100010038˙
Subsystem 4 - Serial number: 010038˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000091608
Coding: 0004417
VCID: 9C749C105F9608C1127-80C9
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E1 955 113 B
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: B6206EB8C17AB291043-80E3
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7272403
VCID: 9B769F0C5A980FF91BD-80CE
Address 0F: Digital Radio Labels: None
VCID: D5E2C9343C3C9989ED9-8080
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0004WA$
Coding: 0532707
Shop #: WSC 08310 444 83450
VCID: A600BEF811DAC211B43-80F3
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 35Y6K
Subsystem 3 - Serial number: 0001.01.0000H0100000000000˙63
Subsystem 4 - Serial number: 000000˙63328RB4010380BBC˙63
Subsystem 5 - Serial number: 380BBC˙63428RB4010380AAB˙63
Subsystem 6 - Serial number: 380AAB˙63528RB4010380800˙63
Subsystem 7 - Serial number: 380800˙63628RB4010380542˙63
Subsystem 8 - Serial number: 380542˙63729RB40105174DE˙63
Subsystem 9 - Serial number: 5174DE˙63829RB4010517A4C˙
Subsystem 10 - Serial number: 517A4C˙
Coding: 0012041
VCID: E582F9F42C5C09097D9-80B0
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F2004234
Coding: 0048263
Shop #: WSC 43480 001 1048576
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 2000306219800E
Coding: FCFE7BDD1B7904
VCID: A71EB3FC16D0DB198F5-80F2
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: A81CB0C01BCED46186F-80FD
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 119089 km
Time Indication: 0
Date: 2015.03.24
Time: 08:46:43
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355CO067563216
VCID: B83C6080CB6E44E116F-80ED
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H03 0090
Serial number: 00000604200014
Coding: 0003477
VCID: 9D729114448C01C9E59-80C8
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCID: A00CA8E073FE2C21CEF-80F5
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040603070392
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000007384
Coding: 0000016
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 20
Reset counter: 252
Mileage: 118021 km
Time Indication: 0
Date: 2015.02.20
Time: 08:29:55
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000080804
Coding: 0010111
VCID: 9E709618498A1AD1FC3-80CB
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T13WN05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
VCID: 9F0EAB1C4E8013D9F75-80CA
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 542
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 357E%0C7538681
Coding: 0000002
VCID: B12A5DA4281495A9511-80E4
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 3301088034
Coding: 344530393135313035412056413033333031303838303334
Shop #: WSC 49308 001 1048576
Subsystem 2 - Part No: 4E0 910 181 C
Subsystem 3 - Part No: 4E0 915 105 A
No Faults Found
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700037919
Coding: 0232125
VCID: DF8EEB1C0E0053D9B75-808A
Revision: 00000000 Serial number: 00000907090290
VCID: B42454B0D706A0813A7-80E1
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720606901488
Coding: 0201208
VCID: A306A7EC62E83739D3D-80F6
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007531867
Coding: 0010900
End-------------------------(Elapsed Time: 07:47)--------------------------
Ross-Tech: Home
Coding: 0007773
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV XXXX
Coding: 4071520
Coding: 0000003
Coding: 0004417
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
No Faults Found
Coding: 0532707
Coding: 0012041
Coding: 0048263
Coding: 0410624
Component: ELV XXXX
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 119089 km
Time Indication: 0
Date: 2015.03.24
Time: 08:46:43
Coding: 4071530
Coding: 0003477
Coding: 0032364
Coding: 0048702
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 20
Reset counter: 252
Mileage: 118021 km
Time Indication: 0
Date: 2015.02.20
Time: 08:29:55
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000532
Coding: 0000018
Coding: 0000002
No Faults Found
Coding: 0032364
Coding: 0232125
Coding: 0032364
Coding: 0201208
Coding: 0010900
The amazing thing is the voice module is mounted on top of the RADIO... I would check
the radio. Some people believe digital radio is the satellite radio, but in the block diagram, the radio is the digital radio. You can actually take the radio out and supposedly can remove the voice module. Check my posts, there must be a picture of the voice module "fins" sitting on top the Radio.
Cheers,
Louis
Cheers,
Louis
Does any one know if I can remove the voice control module (67) from the can gateway list of active modules and activate the voice in the Bluetooth module to test if the mic starts working or do I have to remove the voice module from the system?
I went into the test function in VCDS for the voice control module and voltage, microphones all show "0" value but no fault found in scan. My understanding from the limited info I have found is when the voice control module is installed all microphone function is directed through it? I checked all the coding and it matches what has been suggested Coding: 0010900 for the telephone (77) and Coding: 0000003 for the control head (07). Coding: 0010900 for the telephone (77) is what I have read is required with active voice control. 0010970 I believe activates voice control USA English.
Try just unchecking it in Gateway list, but it is easy to physically unplug Voice Module. Just pull it up. If you want to remove it you have to loose Radio Module (unless there is a different setup in your car).
I have also read that the software revision on both the control head and the voice module must be the same to insure proper function. I believe SW: under each module refers to the software revision? is the complete code listed after SW: the revision or just the first 3-6 characters? end part of the string seems different for each module.
