Testing my MAF sensor on 2004 Audi A8 4.2L
I am getting these DTC's and want to check to see if my MAF sensor is bad. I have a VAGCOM and heard you can do something with the Measuring Blocks to test the MAF. I have researched here and the web and cannot find anything for 4.2L. I must not be entering information correctly because I get different engine sizes but not 4.2L. I have cleaned my MAF sensor with CRC MAF Sensor spray but codes keep coming back. Any help would be appreciated.
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean
Basics
Instrument with VCDS. Go for a test drive while recording data, including RPM and MAF flow rate (in grams/sec.). As it nears shift points (high RPM), you are looking for a peak flow of at least 80% of rated HP measured in g/s. Thus on my 2000 C5 4.2 w/ 300HP, I was looking for at lat 240g/s for example.
1-2 shift and RPM change is fast; easiest to see near 2-3 point. Do not try to read it yourself while driving; either use the recorded mode or bring along a co pilot to read and watch the laptop.
OK, I was not sure what group. So I did 001,002,003 Because I logged it there were alot of lines in excel. I only copied the two highest RPM and G/S. I am not even sure I did this correct. The results below. Advise
Group B: '002
Engine Speed(G28) Engine Load Injection Timing Mass Air FlowSensor (G70)
3320 64.7 14.35 96.31
3200 67.7 13.12 100.5
Group B: '002
Need to get it up toward redline
Group B: '002
Group B: '002
OK here are the (I think) the correct results. I thought I got it to 7000RPM but did not
Group B: '002
6040 68.4 11.48 184.25
6480 64.7 11.07 186.69
6000 66.9 13.12 182.11
Group B: '002
So, you are way off on the expected reading. You can fill in the HP rating of your particular motor, but meantime 186.69/.8 = 233 predicted HP. Not even close. On my 300HP 2000 A6 4.2 with a bad MAF, I pulled slightly over 200 g/s, and of course even that was low for a lower output version. Post MAF change I got up to around 255 g/s as I recall, so it did also validate the rule of thumb for me post-change. My only doubt here is why the load is only showing at about ⅔ on yours. You might also do a run to include throttle position, and make sure that specific element is showing >90% at least. On my A6 it was de tuned relative to D2 A8 and i always suspected it was at the throttle position or body size/diameter; mine would show up to around 95% on throttle position peak.
I did a different version of the MAF test (essentially running it unplugged to see if the same codes popped up) as someone describes here:
https://www.audiworld.com/forums/a8-...2878901/page3/
It's also worth noting that there seems to be a rash of "lean" codes with folks lately (myself included as I started the above thread). For me, running a bottle of BG 44K through a tank of gas took care of my lean codes...and similar actions seem to have been taken by a few others recently (in similar threads). Anyhow, it may be worth $25 and a tank of gas to see if it helps.
However, I do realize your above test shows some MAF issues so that could likely be the culprit.
Well it sounds like I need to purchase a MAF sensor
I purchased one from here. comes with a 5 year warranty, I know is it not a bosch but for the price I thought I would try it
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Ok I got the part in the mail and installed. It did not even register on my VAGCOM. Got a DTC stating "16486 - Mass Air Flow Sensor (G70) P0102 - 002 - Signal too Low - MIL ON". Instead of ordering another one, does anyone have a suggestion what brand I can get that will register and not break my bank account? Thanks
AudiWorld Wiseguy
You already answered your own question....buy a Bosch one before you waste any more time and money on cheap junk parts.
Hardly an expensive part at $150 in the realm of Audi A8 parts.
http://www.ecstuning.com/Audi-D3_A8-Quattro-4.2/ES514002/
