Things Done With My A8L MMI
#11
Button up everything today - now the trunk is clean
Netbook and VGA to RCA converter.
TV tuner and cables
Netbook's video and audio cables to AV1
The bay of all stuff
cables out
Netbook mounting
Tested - everything still works -
Cheers,
Louis
TV tuner and cables
cables out
Netbook mounting
Cheers,
Louis
#14
You have to get the analog TV tuner - <a href="http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313.TR0.TRC0.X4E091 9146&_nkw=4E0919146&_sacat=0&_from=R40">4E0 919 146</a>
You need to install it, <a href="https://www.audiworld.com/forums/showthread.php?t=2851607">make cables and stuff</a>
If you have back up camera installed already, it's very easy. If not, it's more work. You need to get 4E0 035 729 A to have AV (FBAS) input or you can <a href="http://www.dognmonkey.com/audi/add-fbas-to-mmi-head-unit-4e0-035-729.html">retrofit the existing no "A" to "A"</a>
BTW, I found <a href="http://www.amazon.com/AOC-E1649FWU-USB-Powered-Portable-Monitor/dp/B005SEZR0G">a really good LCD</a> which I will change for the display.
If you don't need to display on the MMI, you don't need the FBAS, just connect the Netbook or laptop to the back monitor - splice the audio wire through the CD player or radio wiring to play with the BOSE system. I'm going to try it with my Q7.
Cheers,
Louis
Cheers,
Louis
phantomblacks4nj
S4 (B8 Platform) Discussion
03-14-2010 11:02 AM
TToro 3.2
07-20-2001 09:32 AM
