Solar Sunroof tilting not working.
Few moments ago I discovered that sunroof has 2 ways to be.
Sliding and tilting.
While on internet i was really searching how tilting works I found out that I have to pull a ****.
Sliding works good, but tilting not. Only what I hear after keep pulling **** for more that 10+ sec is this motor.
When I took him apart while still connected I saw that it is turning both ways even if I am pulling ****. I searched from internet anything what looks similar to my problem but no luck.
Anyone know what is wrong and where to dig to make it work? I’m clueless.
The motor in your second picture is the motor for the wind deflector when your roof is open. The deflector has different positions depending on speed to reduce wind buffeting. This has been covered here numerous times because the motor starts making noise so most people have shimmed the motor or in my case, I just disconnected it.
In your case there must be some sort of break in the sunroof so exploratory surgery on the sunroof mechanism to correct the problem.
twogeckos
06-18-2013 01:44 PM
LeadingEdge
07-28-2005 10:37 AM
Avants
12-14-2004 02:53 PM
