Sponsored by:
Sponsored by:
Transmission or engine surge?
Old 05-28-2015, 10:34 PM
nismofreak1208's Avatar
Default Transmission or engine surge?
Hi all.
I repaired my intake manifold changeover valve system by replacing the broken plastic arms with gruvenparts metal 1" arms. When I started the car, there was strong vibration at idle which went away after a battery reset but I get a surge when driving. When driving at speed, example 60mph, as soon as I let off the gas pedal, the rpm needle drops about 300 rpm then goes back up and once I touch the gas pedal again, it's like a rough vibration as it feels like the transmission is catching back up with the engine speed or vice versa. This strange surge and random rough transmission engagements is strange to me. On full hard launch, I get a lag around 6500-6800 as if its a momentary pause or disconnect in power (unless it is when the valves fully open under WOT). I was hoping someone could help point me in the direction of what's wrong.
On a side note, the car feels extra peppy and accelerates harder now.
I'll attempt to take some good video recordings, I tried early this evening but it was a bit blurry
Old 05-28-2015, 11:01 PM
mishar's Avatar
That sounds more like transmission, but some of it may come from those changeover flaps. Are they free to rotate?
Old 05-29-2015, 02:28 AM
Yes, I rotated by hand and there was no issue. There was also no issue afterwards with startup or shutdown with the flaps as they both seemed to have smooth operation
Old 05-29-2015, 06:30 PM
MP4.2+6.0's Avatar
Does sound like tranny. Check tranny fluid level as a logical next step.
caminos
2.0T FSI Discussion
07-09-2020 06:45 PM
twlai
A4 (B9 Platform) Discussion
14
03-27-2017 03:22 PM
chexa4 T
11-11-2003 07:28 AM
nbevins
05-18-2003 09:13 PM
Quick Reply: Transmission or engine surge?
