When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
They are exactly the ones in the photos AEinaD3 posted in one of his LED conversion threads (attached).
They have changed and I have decided to give the SMTII 9 LED Canbus a try. I was told that the Plastice Base will still fit the Socket and are the same Error Free LEDs.
Originally Posted by ModestW12
I don't even know what a light error looks like and didn't see any errors in the car display after I experimented with the lights and then drove my car. I don't know if these light errors show up in vacgom (I don't have access to vagcom to test)?
We haven't had problems with the Puddle and Trunk LEDs throwing Code and I'm not sure that they would. The Error Codes were comming from City Lights and Fog Lights with some LEDs. You would see the Symble on your Dash if there was a Code Thrown.
I cut off approximately 2mm of circuit board and contact strip from the contact ends of the bulbs (right up to the Y at the SY lettering).
Well I guess you can't return them since you've altered the Strips.
Foil is conductive so I could only place some at the ends of the whitish plastic covers where there was little chance of making contact with the metal housing. If I can manage to find a mirrored sticker I'll consider replacing the foil although then I might run into problems with heat melting the sticker and/or adhesive.
My LEDs do not Touch the Foil and I wouldn't bother using the Sticker Mirror. I'd just let it go and call it a Day. Good luck & laters,
