Sponsored by:
Sponsored by:
twin turbo D3 W12 ?
Old 02-20-2017, 05:31 PM
Ceedubbu's Avatar
Default twin turbo D3 W12 ?
I love my D3 2006 W12, car is such a blast but I want more power. I have started researching the feasibility of integrating the Bentley turbo system into my car and then finding someone to custom tune it. Anybody seen this before or has anyone else considered it?
Old 02-20-2017, 06:48 PM
mishar's Avatar
It may be cheaper and definitely better to buy Bentley.
Old 02-20-2017, 07:00 PM
Jack88's Avatar
Agreed, not worth the trouble. If it could be done, it would be massively expensive and would actually make your car worth less as a result. A D4 with the 4.0t would also be an acceptable alternative purchase, those will annihilate a D3 W12 and early W12TT Bentley's in a drag race.
Old 02-20-2017, 08:58 PM
drago_o's Avatar
yep.. I know one guy who made "RS8" from his 4.2MPI and add firstly biturbo, after he broke engine he made it again with one biger turbo. Costs was big. He said it was very near costs like used S8 D4 :P
Old 02-20-2017, 10:05 PM
TSHong's Avatar
Agree with all the post. It would make more sense to adapt the D4 transmission because that is where the increase in acceleration comes from. It would also less headache to buy a D4 S8 instead.
Old 02-21-2017, 12:01 AM
drago_o's Avatar
About engine swap... 4.2TDI from D4 fit D3 with almost non changes 365HP and 780Nm with only oil sensor and main engine computer from D3
https://www.youtube.com/watch?v=f1RG...ature=youtu.be
Old 02-21-2017, 03:39 AM
Jack88's Avatar
I was just talking about the non-S 4.0t blowing the doors off of the rest, you can spend under 40k for one in good shape if you look. An absolute bargain.
Old 02-21-2017, 04:03 AM
aTOMic's Avatar
Hypothetically speaking:
1) Nitrous
2) If anyone in the US can help, his name starts with "Giovanni" and ends with "Giovanno". JJ is on here. He's rebuilding a newish Bentley from a shell (flood car?). Massive undertaking.
3) One of those remotely plumbed turbos. added to your 12. I see why you'd want the Bentley "package" but adding an aftermarket turbo would be more feasible and it here's any room for it, under the car is the place. They even routinely mount them beneath the very rear of truck beds, a place where there's plenty of space on our cars.
4) You could look into changing the gearing and/or tire circumference (smaller tire outside diameter (OD) = lower gearing = lower top speed but more power off the line, effectively). The early 6HP transmission in the Phaeton is geared lower IIRC but has only 5 gears, and probably bolts up.
6) You're nuts. But welcome, you'll fit right in.
-Tom
Old 02-21-2017, 05:09 AM
richard-tx's Avatar
You can get a 4.0t in an d4 L, have it tuned and achieve 650 hp easily. Check APR's website
Old 02-21-2017, 12:25 PM
2001 S8's Avatar
High mileage, one owner 2014 4.0t.
http://www.ebay.com/itm/2014-Audi-A8...m=361909710940
Quick Reply: twin turbo D3 W12 ?
