Upgrade/ Enhancement :cool:
#31
I have gotten all my HID kits from DDMtuning.com. The H7 kit comes with the HID bulbs, ballasts. You will likely need to add the resistors for error free usage. I did this on my BMW 7 series with no issues. Choose the Kelvin temp of choice - 4300k - 6000k which would be the bright white option. Like Mishar said, you will need to drill some holes for the wires. There might be another way, using the existing connection, but I haven't checked into it yet.
#32
The second picture is just for illustration to show the downward bent diesel exhaust tips, and its not my car.
Found this after a quick search, part numbers on second page: https://www.audiworld.com/forums/a8-...-pics-2825375/
#33
The second picture is just for illustration to show the downward bent diesel exhaust tips, and its not my car. Found this after a quick search, part numbers on second page: https://www.audiworld.com/forums/a8-...-pics-2825375/
#34
What hid kit did you use?
What and where did you get your hod kit?
Short update on the LED parking, fog and license plate lights. The parking and license plate lights are now LED and working just fine, no error messages. For the fog lights, the LED also worked fine, but had a 50 watts resistor in the circuit to prevent error message. I only found out the size of the resistor while installing the lights and later learned that they get dangerously hot and could melt insulation on cables it gets in contact with. For me, switching to LED has two sides, one is the obvious cleaner light, and the other is the lower energy draw. So having a 50 watt heat source in front of the intercoolers on both sides was not in line with my wishes. Yesterday they were swapped with 35 watt 6000K Xenon (HID). Now the fog lights shines like newer before and I’m very happy with the result, although they have a slightest tint of green. And no error message for the fog lights too.
And for the straight exhaust tips, the work is in progress, but need to buy some clamps as they don’t fit directly being almost 10 cm in diameter. Think it will look great.
Galco
54
11-03-2018 02:13 AM
Touge.ca
Canadian Discussion
09-22-2015 06:30 PM
ECS Tuning-Audi
09-18-2015 08:08 AM
