Sponsored by:
Sponsored by:
UPGRADED TAIL LIGHTS
Old 09-20-2015, 12:52 PM
tmac2015's Avatar
Default UPGRADED TAIL LIGHTS
Hello everyone I know this is not a new issue but i can't find the answer anywhere. I have put 2009 A8L tail lights in my 2005 A8 W12 and all is well except the rear left outer is giving me a error code. I put old 05 light back in its place and error code goes away. Can i erase code with Vagcom or Open up light and check out. If i need to open and replace less or test how do i get it open it seems to be sealed with no access. Thanks for your time and here is a copy of the errors i received:
Sunday,20,September,2015,16:18:25:12610
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Ross-Tech: Home
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Control Module Part Number: 4E0 910 289 A HW: 4E0 907 289
Component and/or Version: Komfortgeraet H04 0040
Software Coding: 0065086
Work Shop Code: WSC 02313 785 00200
Additional Info: 4E0910853 Heckdeckel H06 0060 4E0907719 Neigungssensor H03 0020
VCID: 275DBF3496DC56063C-8072
Fault Codes have been Erased
2 Faults Found:
00984 - Left Tail Light (M4)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 39
Reset counter: 92
Mileage: 152708 km
Time Indication: 0
Date: 2015.09.17
Time: 15:17:08
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 119
Reset counter: 93
Mileage: 152624 km
Time Indication: 0
Date: 2015.09.13
Time: 08:04:49
Old 09-20-2015, 01:49 PM
Jack88's Avatar
Does the new taillight actually function fully or is there an actual failure of the taillight?
Old 09-20-2015, 01:56 PM
tmac2015's Avatar
They fully function as they should and from just looking i can't see bulbs or anything out.
Old 09-20-2015, 04:29 PM
ltooz_a6_a8_q7's Avatar
Default there is a post that show how to fix this problem. I read
it before, search and you will find it. You need to switch the wire somehow.
Cheers,
Louis
sirh
A6 (C7 Platform) Discussion
09-16-2015 05:32 PM
Nish
S6 (C7 Platform) Discussion
09-14-2015 10:02 AM
jforman
10
09-08-2015 10:03 AM
jhumph88
Q5/SQ5 MKI (8R) Discussion
09-04-2015 10:24 AM
Beena
A4 (B8 Platform) Discussion
09-02-2015 12:01 AM
Quick Reply: UPGRADED TAIL LIGHTS
