Upper control arm change S8
#11
You might be able to avoid all removal and drill press if you have a drill with a securing chain and torque lever. Not sure if that would fit in the confines of the wheel well. A drill press is more accurate but my smaller bit drifted off center in the hardened bolt.
Always replace those bolts with ones from VW/Audi. They are treated for the dissimilar metal types and well worth the cost.
#12
Fortunately most likely...
Fortunately most likely, he's a California car like me, so less risk. Dealer had mine out at times though, but probably true for a fair number back under warranty. One of mine was easy, other just a bit stiff but a few taps or some screwdriver action (against head only, never pinch area) was all it took
If both ends snap off, you have to remove everything and work on a drill press. I did and still was unsuccessful so the old snapped off bolt somewhat hollowed out is still installed. I was able to drill a smaller hole through but it drifted off center. When I attempted to go larger, I was hitting the ball joint ends which are hardened through and could not be drilled. Instead, a smaller bolt was installed to provide peace of mind.
#13
I'll definitely get these bolts before starting working on it
next week. Never work on a Sunday with suspension without extra bolts and nuts. Thanks for all your helps, so glad MR Bally warned just in time. I know, CA cars may not have the problems, but clumsy me may screw them up.
I did measure the height from the knuckle to the top when the car on the ground, so when I place the new ones on, I'll jack the suspension up to the correct height before tighten everything down.
Thanks guys,
Louis
Thanks guys,
Louis
#14
Like my late Dad once told me; an uncle once said to his son who was building a model wood boat and needed brass wood screws on Sunday; "I know where thers's a hardware store open on Sundays". It was my Dad's workshop . He had a hardware assortment (boxes of every fastener known) all marked and in order. This was in the era of no Home Despot/Menards/Blowes etc. And Ace Hardware as well as True Value (Hi, Pat Summerall here) were six day a week operations. Now we have 24/7 places. Anyway, my dad's stuff that I inherited was pre-Metric but I have a small assortment of Metric hardware too. I can make Non-Metric stuff work for temporary fixes and have used thos heavy duty bolts, washers and nuts on many exhaust systems in the past. The price was right as well.
#15
Louis,
I have some spare bolts and nuts if you run into any trouble. If you car has been a CA car it's whole life, removal should be quite easy. Just ping me if you need them over the weekend.
#16
Thanks,
I'll get some at Carlson Audi this week sometimes before the weekend. If I break all of them and the new ones, I'll definitely ping you. How's your A8L these days?
Cheers,
Louis
Cheers,
Louis
#17
Another trick that may help remove the sized or non-sized outer bolt. After spraying it down with wd-40 etc. and letting it soak, try to loosen it normally. If you want to get tricky, loosen the nut till just on the last three or 4 threads, place socket on bolt end. Using large c-clamp apply some pressure and see if (using vice-grip on socket) if you can get the bolt to turn. I got the passenger side bolt free this way, eventually switching over to a deep well socket and pressing the bolt into the socket. Use plenty of penetrant. ; )
big_anthoiny
11-04-2008 03:13 AM
MingsS4
07-10-2007 04:13 PM
topthis$A4$
09-11-2006 09:03 AM
brrman
04-15-2003 06:12 AM
