Upper control arm pinch bolt advice - AudiWorld Forums
Old 03-14-2014, 05:17 PM   #1
Default Upper control arm pinch bolt advice
So I'm trying to do my upper control arms and of course I am stuck on the first bolt. I have been shooting it with PB Blaster every night for the last few days but it is stuck fast. Of course there is no way to hammer it out from the other side like you can on the A4s. I am sure I am not the only one who has encountered this. What have you done that worked? I haven't tried heat yet but my torch set is not here right now. Help...
krazzz is offline   Reply With Quote
Old 03-14-2014, 07:37 PM   #2
03_AR_CO's Avatar
I have not had the trouble with the D3's, did on on my allroad, but had enough room to get a drift and a maul in there to encourage it out.
03_AR_CO is offline   Reply With Quote
Old 03-14-2014, 09:21 PM   #3
mishar's Avatar
<iframe width="560" height="315" src="//www.youtube.com/embed/TvCanD6uEtQ" frameborder="0" allowfullscreen></iframe>
But torch would do it better. Just be careful with rubber seals at the ball joints.
mishar is online now   Reply With Quote
Old 03-15-2014, 09:01 AM   #4
03_AR_CO's Avatar
Thats an interesting video Mishar, I have had some difficult pinch bolts to remove, but nothing like that one, and hopefully will never have to. Lesson learned, stay away from Minnesota cars.
Old 03-15-2014, 10:09 AM   #5
snapdragon's Avatar
One of mine came out with an air chisel which I bought especially to try and finish the job, it was not that useful due to the obstructions making the angle of attack obtuse., The other side was solid despite plus-gas over a month. Air chisel got nowhere maybe moved it 1mm, didn't want to heat too much due to it being aluminium, I tried it but it just doesn't hold the heat like steel.
In the end, I turned the head with a breaker bar until it sheared off, then then started to drill it out with bigger and bigger bits while squirting oil on until I was worried obout it bursting out.
After a bit, I took the nut off and put a greased washer on the threads and put the nut back and just tightened it and it started pulling what was left out little by little until the nut reached the plain bit at the end of the threads. After that it was out enough to use a hammer and an old 8mm drill bit.
Lathered the whole thing up with Waxoyl when replacing.
snapdragon is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
PARTING OUT 2002 A4 B6 1.8T Cmmartin23 Parts For Sale 26 08-23-2016 05:44 PM
An ounce of Pinch Bolt prevention ohsigmachi A8 / S8 (D3 Platform) Discussion 4 03-29-2016 06:04 AM
First Experience with Audi Dealer Service Dept. the_duke A8 / S8 (D3 Platform) Discussion 6 09-10-2015 10:02 AM
Thanks for helping! (New D3 owner) LONG CPLYONS A8 / S8 (D3 Platform) Discussion 7 09-07-2015 08:19 PM
:: ECS Tuning :: MKI TT ECS Assembled Control Arm Kit Collection ECS Tuning-Audi TT (Mk1) Discussion 0 09-01-2015 01:25 PM
Tags
a8, bolt, d3, pinch, upper
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
