Upsizing brakes
#51
If you screw up radio coding it's one thing, but this... you mustn't.
The documentation in VCDS wiki is the Ross-Tech value add - that's why you don't see every DTC listed.
Same reason we lock our doors
As you start coding newer models you'll find the access codes aren't available anywhere except within VCDS itself.
The easy coding we are used to on D3 is sadly a thing of the past with UDX, and other challenging things like the 'byte 18' issue.
NB: Version 14.10.0 is out along with a firmware upgrade for the dongle.
#52
#53
Getting into FMVSS territory and liability here.
If someone will do this... mostly to line lawyer pockets in exchange for a $1.40 pickle voucher... just imagine what they would do if ABS didn't function they way they thought it should
Yes. Damn kids.
However it's not just a matter of stealing someone else's hard work.
The modules communicate differently now and have many channels - think 255 channels for each old byte.
Instead of 7 bytes you have something like 44E6F20022674F00E200 or 09072091073C9FE18B000804A0003800009CD3088200012180 01085C3B00
Those are my module 03 and 09 codings, respectively.
Based on pull-downs the long coding helper Niels wrote computes the changes, and examples can be seen here.
This adds up to a mountain of information that Ross-Tech chose not to publish (along with the security codes) and instead include in encrypted label files for newer vehicles/modules.
The days of adding +4 to a code to enable/disable something are pretty well gone....
All this said the SAC is available in factory repair manuals most of the time.
There probably aren't many changes for the D3 but always good to have latest version of VCDS.
Last edited by jakematic; 11-06-2014 at 09:16 AM. Reason: added class action lawsuit link
#54
Scaring us is their way to take over everything. Resistance is not futile.
I was talking about free offer of hackers IP. Nobody is going to steel Audi ABS software and use it on Hyundai (if they need it they will get it from Bosh ). But somebody might come with a good idea, share it here and Audi can have it for free. If Art is not too proud?
I don't think there's a need to get into IP issues here.
#55
Art is very proud ! And stubborn
#56
As it was kinda decent temperature outside today, I used the opportunity to change to brakes in the front. Very easy operation, it’s just to unscrew and disconnect everything and then all in reverse with the new stuff.
The new disc on the right and the old one on the left.
The new and old dust shield. Didn't need to be replaced for space, but I guess they didn't make several sizes for fun.
The old front disc on the left and the new rear disc on the right.
A few observations so far:
No left or right carrier, both look exactly the same.
No left or right caliper, it all depends on where you connect the short brake pipe and the bleed screw.
The brake hose for the bigger sizes brakes are slightly longer than for the smaller ones, not sure why as I can’t see the short one being too short for the bigger brakes.
With only the big ones at the front, then brake balance is obviously not good. Don’t have to press the pedal much before the front tires screams for mercy. But probably better than starting with the rears first, that could be more than interesting in braking situation.
Did just a short test drive today, and the ride comfort is remarkably similar to before, despite the increased unsprung weight.
#59
So, finally I did the rear brakes too. A simple bolt on, but I decided to take the calipers off to be painted as in I did in the front.
First a picture of the new and old rear disc.
And then one on the car.
And finally with the wheel on.
A few observations in the rear.
Left and right carrier fits both sides, not sure which one is correct but I chose the one I think looks best.
There are two brake hoses on each side in the rear, and the outer one for the bigger sizes brakes should be slightly longer than for the smaller ones. Although the short one fit, it’s tight to get the caliper over the pads. Will probably replace all four in the rear during next year.
VCDS gave me no problem with EPB.
Just a short test drive today too, but already the balance feels much better.
ECS Tuning-Audi
RS4 (B7 Platform) Discussion
08-14-2017 08:39 AM
ECS Tuning-Audi
09-28-2015 12:18 PM
