Sponsored by:
Sponsored by:
Vag Com for seatbelt chime 08 S8
Old 08-17-2011, 09:07 AM
  #21
AudiOx's Avatar
Originally Posted by jakematic
......That damn door open chime drives me batty though......
amen! I turned off the seatbelt chime, but the door open one is pretty annoying.
Old 08-17-2011, 10:58 AM
  #22
aceecaus's Avatar
My bad, I said seatbelt chime and I meant door chime. I'll try the ROW and switch back to imperial through the MMI.
Old 08-27-2011, 12:57 PM
  #23
jakematic's Avatar
Finally had time to try this today.
If you change module 17 coding to 1 it will turn off the door chime.
Code:
xxxx?xx: Country
1 = Rest of World (Left-Hand-Drive)
It initially flips the display to km.
In MMI my units still said miles, so I flipped to km and back to miles.
DIS now shows miles everywhere except consumption - that shows as litres which is fine with me!
Old 04-05-2013, 10:05 AM
  #24
Incaico's Avatar
Seat belt chime is easy:
Module 17 - Instrument cluster
xxxxx?x: Seatbelt Warning (3-6 = MY 2005+ only)
0 = No Seatbelt Warning
1 = Seatbelt Warning (EU-NCAP)
2 = Seatbelt Warning (NAR Old)
3 = Seatbelt Warning (NAR New)
4 = Seatbelt Warning (EU-NCAP incl. Passenger)
5 = Seatbelt warning (NAR Old incl. Passenger)
6 = Seatbelt Warning (NAR New incl. Passenger)
Works perfect!
Thanks!
Old 04-05-2013, 06:18 PM
  #25
Incaico's Avatar
Originally Posted by Incaico
Works perfect!
Thanks!
BTW, I have lost my "beep" when I arm the alarm on the car. Must be connected to seatbelt chime?
Old 04-05-2013, 09:39 PM
  #26
mishar's Avatar
No. There is separate setting for that beep.
Old 04-06-2013, 04:49 AM
  #27
jakematic's Avatar
As Misha said, it is under [46]: http://wiki.ross-tech.com/wiki/index...Comfort_System
+0001024 = Anti-Theft Warning System Confirmation via Horn (PR-A8U)
Old 11-02-2014, 07:01 AM
  #28
QuattroDaniel's Avatar
Code:
xxxx?xx: Country
Just did this, worked great - thanks all!
Do we know if there is a way to have Consumption changed to Imperial? (MILES per GALLON instead of LITERS per 100 KM?)
Old 11-02-2014, 08:29 AM
  #29
jakematic's Avatar
Not that I ever discovered...
Old 11-02-2014, 08:50 AM
  #30
mishar's Avatar
It may be better not to know on this cars.
Magic number is 15.5. It is same for mills per gallon and liters per 100 kilometers. If you are lucky it will be somewhere there.
Quick Reply: Vag Com for seatbelt chime 08 S8
