Sponsored by:
Sponsored by:
2008 S8 Engine ticking / clicking noise
Old 05-22-2023, 10:18 AM
Badhabbit's Avatar
Default 2008 S8 Engine ticking / clicking noise
Hey guys. My 2008 S8 (Euro spec) developed a loud clicking noise from the engine bay. It sounds like it is coming 4 inches behind the driver side hpfp, and it intensifies with rpm. I do not have a stethoscope, so I can't try to isolate it this way at the moment.
I scanned the car and the only code is P0441 which is the purge valve. Naturally, I replaced it, but the clicking persisted. I also disconnected it for a minute, but that made no change at all.
Apart from the clicking, the car runs fine - smooth idle, no misfires. The intake flaps have been deleted by the previous owner and tuned out.
Now, in my mind the possible culprits are hpfp, injector or lifter. I have attached a video of the car making the sound while moving.
I would really appreciate it if someone has any ideas on the issue.
File Type: mov
Old 05-22-2023, 10:10 PM
Badhabbit's Avatar
I was just told it might also be an exhaust manifold leak. Does this sound legitimate?
Old 05-24-2023, 10:06 PM
Badhabbit's Avatar
Default Update
After some spirited driving and several pulls to redline, the ticking is gone, and the cars works as it should. I honestly have no idea what this was. Has anyone ever overfilled the v10 with oil? Could this actually cause a ticking noise? I'm not saying that I have done it, I'm just wandering if there is a chance that I have overfilled it by accident.
Old 03-18-2024, 08:45 PM
florinb92's Avatar
On my Q8 I have the same ticking sound but I can't get rid of it lol
did your came back or it got "fixed" permanently ?
Old 03-18-2024, 09:23 PM
Badhabbit's Avatar
Default Solved
For me it was coming and going for a while until I decided to dive deeper. Turned out to be a worn out injector that was making the sound. Keep in mind the sound is almost identical to lifter tick, so it could also be that. Does your car have any accompanying symptoms? When do you hear the ticking?
Old 03-19-2024, 12:03 PM
trilis's Avatar
It could be washer under the injector, please try to change
Old 03-20-2024, 01:01 AM
Badhabbit's Avatar
If the washer under the injector is making the noise, would it be fair to assume there would also be compression leaking, as it would not be seating properly? It might also cause play in the injector.
You can use VCDS to check the fuel trims and see if there is compensation for some actual issue with the injectors.
Old 03-21-2024, 02:57 PM
AudiWorld Wiseguy
dvs_dave's Avatar
Throw some injector cleaner in the tank and drive it hard in manual mode for at least 10 miles with the rpm over 3000+. That should get the oil flowing and fully pressurizeany lazy lifters, and clear out any sticky injectors.
The old Italian tuneup.
Old 03-21-2024, 11:54 PM
Badhabbit's Avatar
I wouldn't disagree with this, it is always good to stretch the legs of the engine, but this definitely did not work for me. I even soaked the injectors in cleaning solution without any effect. They were basically shot. If this knocking is from the injectors, chance is that you will have to replace the faulty ones.
Other possible culprits are HPFP, lifters, chain guides, evap purge valve.
Are you able to locate roughly where the sound is coming from?
CasmeticRooster
A4 (B7 Platform) Discussion
02-27-2023 06:28 AM
amusa
2.0T FSI Discussion
11-08-2021 01:03 AM
Juriy23
04-17-2020 08:10 PM
PaulW
02-21-2019 01:15 PM
Avus_'03_S8
02-14-2007 08:08 PM
Quick Reply: 2008 S8 Engine ticking / clicking noise
