Weird Noise On Startup
So I have noticed that upon startup when it has been sitting for awhile I get a loud grinding noise that lasts for about half a second and it appears to be coming from the steering column or inside the dash. When I turn the car off and start it again there is no sound, only when it has been sitting for a bit.....say 2 hours. I don't see anything moving until a second later when the noise has stopped and the tweeters and MMI screen rise. I don't hear any hissing sounds or what sound like a compressor either.
AudiWorld Wiseguy
Nothing should be making a noise like that unless it's faulty. I'm giving you ideas what to check. I.e Interior motors that run the first few moments after inserting the key/key on.
probably just one of the vents actuator or something fell in the cabin filter box.... goto the front remove the cabin filter and see if anything strange is in there. look really good, if not check the vents actuators, that is the motors that moves the electronic vents, especially the fresh air vents, the reason you don't hear it immediately, because after the car/gateway goes to sleep the vents close. that takes a while like maybe 10 mins after you close/lock the car. also it could be just one of them defective but that's rear, so you got your work cut out for you.... tip: you can use a high pressure vacuum and suck the vents to see if anything comes up, but you will need to do a dash teardown.... good luck...
I am thinking it is the steering column unlocking, will get that looked at. On another note when driving out of my parking garage I can hear the brakes echo off of the walls rubbing like tsst....tsst....tsst....tsst should this sound go away after driving a bit or should it not be there at all?
Well, I am on the top of the garage (5 floors) and I still hear it when i leave, without depressing the brakes. It goes away after they heat up apparently a few miles down the road.
Also,just went from Ft. Meade, MD to Johnstown, PA (about 200 miles). It appears that both the braking and acceleration have 2 stages, depending on how firm you depress the pedals, have to get used to that.....have to say though that the ACC works amazing, glad I have that feature.
