Sponsored by:
Sponsored by:
Is this what the vacuum pods on a 4.2 are meant to look like?
Old 03-26-2015, 01:09 AM
mattsimis's Avatar
Default Is this what the vacuum pods on a 4.2 are meant to look like?
I can't see how the one on the right hand photo side does anything with an arm that long!?
Old 03-26-2015, 03:06 AM
mishar's Avatar
You are right. It can't do anything. That's not original arm. There are aftermarket aluminum arms available. Just search the forum. Also check if the flaps are stuck.
Old 03-26-2015, 06:35 AM
2001 S8's Avatar
Wrong arm size installed, as stated by mishar.
There are two different lengths; 2 inch arm and 1 inch arm. On the D2 models with 4.2 engines the A8 uses the 2 inch arms, while the S8 uses the 1 inch arms. There must have been a design change, between the D2 and D3 converting the A8 arms to the 1 inch length.
See link below for arms mishar mentioned.
Audi/VW 4.2 V8 Intake Manifold Linkage Arms - Gruven Parts
Good luck.
Old 03-26-2015, 07:11 AM
jamm220's Avatar
Gruvenparts.com out of Atlanta sell them. Really nice guys/good customer service. I've used their arm and also the cooling pipe came from them
Old 03-26-2015, 07:03 PM
mattsimis's Avatar
Excellent, good to know I can spot stupidity by PO!
So to be clear is only the right arm wrong (should by 1inch), so I need a replica of the left one (same on both sides?).
Old 03-26-2015, 08:53 PM
winy68's Avatar
I too bought replacements from gruven. works great and will never break unlike oem replacement
Old 03-27-2015, 04:54 AM
2001 S8's Avatar
Yes the right arm needs the 1 inch arm. When your car is turned off the pods should be extended or look like the left one in your photo.
Changing out arms should be pretty easy. Just pry off old arm and press in new arm. It's a ball and socket set-up.
Good luck!
Old 03-03-2016, 08:35 AM
Alexmsk's Avatar
Somebody bought linkage arm on this site?
link
looks great
Old 03-03-2016, 08:38 AM
Alexmsk's Avatar
link
looks great
linkage arm
05SilverA8
42
11-19-2021 06:55 PM
115k
Q7 MK 1 Discussion
04-24-2018 08:36 AM
idf
24
08-09-2015 10:08 PM
Ponaitis Tadas
10-30-2013 11:14 AM
MingsS4
07-10-2007 04:13 PM
Quick Reply: Is this what the vacuum pods on a 4.2 are meant to look like?
