Will fix-a-flat damage TPMS?
I have always kept a can of Fix-a-Flat in my car. For most small leaks, like nail holes it will get you to a garage. I have a can in the A8, but have not yet needed to use it. I had a thought. Would using it damage the pressure sensing valve stem?
Thanks
Thanks
No...
putting aside whether to use it or not, technically it shouldn't affect it.
The sensor part of the unit is sealed--as in, you can't change the batteries absent a homebrew cut it open approach. The stem is just barely exposed on the inside--a small amount of the ball shaped area where it fastens to the sensor and allows a little fit adjustment. Even there, an inner rubber sealing washer basically covers it. But if you don't change wheels, you wouldn't touch it to start with unless the batteries go low. Could easily be wiped clean even if anything got on there. Theoretically it could get in the back of the torx head screw that attaches the sensor to the stem (the only way it is actually mechanically fastened). But again that could be picked out, and torque on it is light anyway--no more than modest screwdriver torque basically. Plus, the goop will tend to get thrown outward toward the tire anyway when the wheel spins.
Tire monkeys will curse at you though.
Woke up Sunday to find my B8 back right running low. Drove it to church and when I came out of church it was lower... Was about 1/4 mile to a Pep Boys so made it there with the thought that I can put fix-a-flat in and bring it to my regular ture guy next to my work today...
When I walked in and told him my story, both mechanics said "oh ****" out loud. They have seen numerous sensors can completely ruined by the fix-a-flat. When he looked through the Audi manual, it actually says do not use it... Luckily he was able to wipe off the gook and it is ok (Thank God)
I pay like $12 a year for Geico roadside, I definitely learned my lesson this time and will not be using it ever again!
The latex sealant is pretty everything friendly - like Green slime. But that fix a flat is nasty stuff, what a horrible smell and sticks to everything.
Tire sensors look pretty robust to me, they would have had to design with sealant or some tire goop (bead sealant) in mind.
From the fix-a-flat website:
Will Fix-A-Flat® damage my tire pressure monitoring system (TPMS)?
As stated on the can, it is important to have your tire inspected and repaired as soon as possible and notify the tire care professional that Fix-A-Flat® has been installed. At the time the affected tire is inspected by a tire care professional, they should clean the sealant from the tire, prepare the area and repair with a Rubber Manufacturer’s Association (RMA) approved patch/plug. The TPMS device should also be cleaned off with water to remove any sealant which may have come into contact with the device. After the repaired tire is replaced and inflated the TPMS system will resume operating as normal.
ejfiii
25
05-19-2017 10:47 AM
TwentyValveB5+S4
05-21-2005 06:57 PM
