Sponsored by:
Sponsored by:
Wire Harness and plug under Battery Compartment
Old 04-29-2016, 01:58 PM
  #11
Banned
JohnnyJ A6Q's Avatar
Originally Posted by Yllier
Indeed it did turn out to be the Air Suspension Module. The MMI still wont turn on and VAG-COM scans show that it appears to be disconnected from the Optical bus
Hello Yllier,
Did you look at the PDF posted by ScottCNelson in post # 3, it shows the location of EPBCM under battery.
That does not look at all like the air suspension control module connector, it looks to be as already stated the "EPB" electric parking brake control module connector.
4E0907801 | eBay
Old 04-29-2016, 05:03 PM
  #12
Pothole5000's Avatar
This car was a stolen recovery.....
I would have started with this. There is a member here (wug) who will run your vin number, that may give you a starting point of everything your car is supposed to have.
https://www.audiworld.com/forums/a8-...843984/page27/
Old 04-29-2016, 05:19 PM
  #13
Engineer
Shamoye Lewis's Avatar
Given the optical lines not damage to u need to get atleast amp and radio tuner to get going, close loop the rest get cd changer also if it missing from the glove box, only amp and cd changer need component protection removed, if radio has sds that to, if you don't have factory bluetooth which I didn't see in the scan it's unlikely you had sds, so a non sds tuner will do.
Old 05-02-2016, 05:46 PM
  #14
Yllier's Avatar
Originally Posted by JohnnyJ A6Q
Hello Yllier,
4E0907801 | eBay
Thank you so much for the information . Being shipped to me as I write this
Lucas Larson
02-27-2020 09:37 AM
mikesd1980
02-16-2011 01:14 PM
AudiQmann
02-25-2006 04:04 AM
sheeleydog
12-13-2001 07:47 PM
Quick Reply: Wire Harness and plug under Battery Compartment
