2011 Audi A8 shifting issues when cold
#11
Nice to see another Washingtonian on here! Gig Harbor is a great area....I went to HS across the Narrows.
I, too, have suffered through rough shifting at times especially when cold. Unfortunately, it seems to be problematic with all D4's. Not sure what fix exists if any. Some have recommended a tranny software update but I had that done with no improvement.
That's too bad about the tranny update failing to improve anything. I will talk w/ Larson Audi in Tacoma about it but i have little faith. My practice is located near Belarmine HS by the narrows. Any other pointers on the vehicle or recc independent shops for maintenance ?
#12
I have a 2013 A8L 4.0. 20,000 mi. It has developed what I think is a shifting issue similar to that described elsewhere. From a cold start up to about 30 mph I feel a shuddering as it is changing gears and it seems to hold on to first gear to about 4,000 rpm. I admit I don't let it warm up a lot as I like to conserve fuel, but I had not noticed the problem before. Ideas? Is this transmission under a recall for a fix? I had a 2012 with the same transmission and never s problem. Thanks in advance.
#14
I have no idea if the ACC light was on before buying as I purchased out of state and shipped vehicle. Dealer claims there was no problem but honestly, they probably didn't even see it as they are an Acura dealer and unfamilar w the car. I have seen a lot of curb rash beneath the front bumper. Prior owner wasn't good at judging distance I see, so that could have caused it. There is history or evidence of front end crash either, so maybe being jarred too hard on a curb. I will look for the sensors as i am unfamiliar where they are. The hard/delayed shifts are a real bother when coming from a rolling start. The tranny holds between gears and finally goes into 2nd after 1-2 seconds. this can actually be dangerous if I need a quick accel because I pulled out in front of someone. I saw another forum on here as well about that. I don't know if the dealer can reprogram the computer but I will soon take it in and have an assessment done on it. Same with the vehicle thermostat. I had a 2000 A6 posting poor gas mileage until I had the thermostat replaced and it made a big difference. There are also those annoying clicking sounds coming from the left of the streering wheel. Car is now out of warranty so it is sounding like some big bucks to resolve these issues. Any other thoughts? I greatly appreciate your time! truly
Were you able to have yours repaired and if yes what was the issue.?
#15
I'm surprised you guys are not having the dealer or an independent shop drop the pan and replace the filter / about 8 quarts of the transmission fluid. Every transmission manufacturer recommends they be serviced. They are designed to be serviced. It is only the vehicle manufacturers who invent the term of a lifetime fluid to make the vehicle appear to need less maintenance. It's really bad for the units longevity. Lexus tried to pull the same crap for U.S. vehicles. If you want your transmission to last you absolutely need to service the fluid and filter depending on the vehicle. Some don't have traditional filters. The cost is about $600 from an independent German vehicle specialist. Probably about half that if you just do a drain and refill.
#17
I plan on dropping my pan within the next 10k miles. Or maybe just a drain refill. Not sure yet. Independent shop says they recommend every 90k but I personally think every 60k is better. Probably do the differential and fuel filter at the same time.
#18
The clicking sounds like a relay right to the left of the steering column behind the dash. its definately electrical. I have just never heard such a blatant relay in all the cars I have owned, especially of this caliber. I'll kook for the cruise sensors in the would be fog light area as the car has the LED lighting package. Mayeb I should purchase a VAG unit myself vs taking it to Audi just yet. Our local Audi in Tacoma WA is not well rated or reliable requiring me to go to Seattle.
#19
For the transmission issue, I have some bad news based on my recent (last 2 years) experiences with this car. In fact I just got out of a 1.5+ year back and forth with the dealer and audi canada for my 2011 4.2 8sp where they replaced the mechatronics twice, controller, did 4 "re-adaptations" and numerous software updates trying to fix this stubborn shift at low speeds (and particularly bad when cold, accompanied by the relay clicking just as you describe). In the end they finally changed the transmission after I showed 10+ videos demonstrating long delays of 3+ seconds followed by jarring hard lock-up when rolling off of a stop (or slowing down to take a corner). After about 1.5 years of being assured by the dealer and audi canada that this was normal, and driving it with this condition, it would occasionally make some bad whining noises like gears meshing. At the end, it started hard-locking so hard the car would actually restrict itself to 1500rpm for 5-10 seconds after, which was what caused me to raise the flag at the dealer and start recording it.
I test drove a 2012 with similar mileage (40k miles) and it had the exact same symptoms but less drastic. Very easy to reproduce, get up to 40mph, slow down to 5-8mph (as if you were slowing down to turn into a parking lot, or out of a parking lot) and then switch from the brake to the gas - it will free spin for some amount of time before reaching a timeout inside the controller and locking up (this is the relay clicking). It is much more pronounced in very cold weather (~-30C/-20F).
The worst news is it still does it occasionally (although much less worse), leading me to believe it will eventually degrade again over time. Looks to me like Audi just did a very poor job at dialing in the transmission maps and it causes excessive hard lockups in 2nd, wearing the transmission prematurely. The car had 45,000km (under 30,000 miles) when it started doing this so I highly doubt its due to fluids.
I've driven the A8 4.0T and 3.0 and they have no such issue. Seems like **** luck, but this model (4.2fsi w/ZF 8sp) was only made for 2 model years and they don't seem motivated to fix this problem.
Maybe somebody in the aftermarket will make a proper map/program for the transmission.
#20
