Sponsored by:
Sponsored by:
A8 4.0 Engine Vibration MUST READ!!!
Old 10-01-2016, 09:21 PM
  #121
Baloo588's Avatar
Originally Posted by derfA8L
Nor would you feel it on a 2015+ A8 since Audi effectively addressed the problem with revised and insulated suspension components, as well as adding a damper on the front axle. Made a big and positive difference between my 2011 and 2015 D4.
I remember reading your post on this a while back. I drove the newer A8 from 2015 plus and they are very quiet and smooth. At this time I have 115k on the 2012 A8 and i will go for the newer generation A8 when it comes out and order one in 1-2 years from now.
Old 10-02-2016, 08:05 AM
  #122
derfA8L's Avatar
Then your timing is on target with the US launch of the D5...Spring 2018.
Old 10-17-2016, 10:44 PM
  #123
Steve155's Avatar
Brought the 8 into the dealer and sure enough Audi corporate opened a ticket and had the dealer order new down tubes to be installed. Hope this remedies the vibration / shudder issue
Old 10-25-2016, 04:41 PM
  #124
Ngerstman's Avatar
Originally Posted by A8youup
Got my car back and the vibration is gone! Thanks guys!!
I test drove a 2015 s8 today and sure enough there is the vibration at 3000 rpm! Amazing they all haven't been fixed yet. I'm still a bit confused on this issue. The TSB says it's an engine mount sensor issue and all you guys say it's a down pipe issue and the mount issue fixes nothing, correct. Still no TSB that says it's a down pipe issue? The car I'm looking at is a beauty with 16,000 miles, cpo as well. Might put in a bid contingent on them fixing the vibration. Thanks. Regards. Ned.
Old 10-26-2016, 05:59 AM
  #125
the_duke's Avatar
The TSB states that if the vibration doesn't go away after the module re-programming that the tech should then open a TAC ticket. That is when they step in and replace the down pipes. I will be taking my 2013 in for this soon. I'm hoping the re-programming fixes it but from what I've read here it seems that if your car has the vibration it almost always ends up in a new set of down pipes as the final fix.
Old 11-02-2016, 10:37 AM
  #126
Tyreabusa's Avatar
Default A8 4.0 vibration
Just picked up my certified 2013 A8L and immediately noticed the vibration. The dealer took it back, did all the upgrades with the engine mounts etc, but eventually cured it by changing the down pipes. Why this cured it I didn't want to ask. Now runs smooth at any revs on any cylinder configuration.
Old 11-02-2016, 11:49 AM
  #127
the_duke's Avatar
I just scheduled mine to go in on Saturday. Hopefully it goes well.
Old 11-06-2016, 09:00 AM
  #128
Graham4242's Avatar
Thanks to this thread the dealer replaced the down tubes straight away without any messing about. Now butter smooth all the way through the rev range.
Old 11-10-2016, 01:34 PM
  #129
sergiitkach's Avatar
Default A8 4.0 how to resolved Engine Vibration
The best and chip way to resolve tlvibration on a 4.0T buy flex pipe 21/2 by 8 and weld. I pay 50$ flex pipes + labor.
Old 11-10-2016, 01:49 PM
  #130
the_duke's Avatar
Why would you do that when it's fixed for free under warranty?
Quick Reply: A8 4.0 Engine Vibration MUST READ!!!
