Sponsored by:
Sponsored by:
Any way to delete the old phone directory?
Old 06-13-2013, 06:57 AM
xradman's Avatar
Default Any way to delete the old phone directory?
Here is the problem. I changed my phone recently and it's working properly with MMI. However when I went to program voice command for my common numbers (spouse, children, etc) it says that similar sounding entries are already in the system. They are from my old phone for which MMI apparently still has the directory in memory somehow. However it's not accessible for dialing or voice command and there does not seem to be any way to delete this old directory so I can reprogram voice command to use the same name in my current directory. Am I missing something here? Is there a way to delete the old phone directory either from MMI menu or even using VAGCOM?
Old 06-13-2013, 07:34 AM
jakematic's Avatar
Go to Directory, then press Settings, then Delete Directory.
There should be a selection to Delete Public Contacts and Delete Name Tags as well.
Old 06-13-2013, 07:35 AM
xradman's Avatar
Originally Posted by jakematic
Go to Directory, then press Settings, the Delete Directory.
That deletes my current directory but not the directory from my old phone which I no longer have. There's got to be someway to reset the system to clear the memory.
Old 06-13-2013, 07:40 AM
jakematic's Avatar
Maybe Telephone > Settings > Delete All Entries
Old 06-13-2013, 10:30 AM
xradman's Avatar
Figured it out. It's under CAR>MMI Setup>Factory Default>Directory
Old 09-29-2013, 03:03 AM
Powdermike's Avatar
Default Deleting the directory from old phones.
Very important (at least in the S7): after clicking /highlighting Directory, scroll to the bottom and click on reset. Then yes.
The MMI will shut down, completely and the display will retract into the dash. When it turns itself on again, you'll have 5000 entries left and the old phones are gone - finally.
Thanks everyone.
gilvet
S4 (B8 Platform) Discussion
02-01-2017 01:13 PM
IDRPEA
09-06-2013 09:03 AM
DrasonDC
Q5/SQ5 MKI (8R) Discussion
01-13-2013 03:48 PM
Object
A4 (B7 Platform) Discussion
08-15-2007 04:27 PM
Vee8
02-18-2007 12:54 PM
Quick Reply: Any way to delete the old phone directory?
