CPO Requirements
#11
So, I got the parts from Meadowlands Audi (I mention, because I believe they're a sponsor). They're local enough for me to go in person, and Jeremy at the parts counter was very helpful and friendly.
I've now done every part of the service except the pollen filter and the brake fluid flush. All in all it's pretty easy. It's amazing how thoughtful the engineers are when it comes to servicing.
This was my first experience with a fluid extractor and filter cartridge for the oil change. I'm never going back
I went for the OEM NGK plugs. The old ones looked quite used! The coil packs took a considerable amount of force to remove - and I was surprised at how the torque spec felt installing the plugs, considering how easy the old ones were to remove.
The only issue I have is that the car always thinks I've got the hood open now. My temporary fix was to unplug it. I must have jostled something when I was working on the air filter on the left side - but I can't figure what.
The engine idles smoother and, maybe it's my imagination, but also seems a little more responsive than it was. I don't remember my other Audi's changing character after scheduled maintenance - but, I haven't had a non-turbo in many years.
I give the procedure a 3 on a 1-10 scale. Anyone who wants to save $1k should seriously consider doing the 50k mile service themselves!
#12
#13
Former Vendor
Pete,
Thank you for the kind words! It is much appreciated. Im glad to see you had an enjoyable time working with your car. Im sorry to hear about this hood problem. There are 2 latches for your hood on the A8. I would first double check (as silly as it sounds) that the hood IS completely closed. If sure, go in and look at the hood latches themselves (to the left and right of the top of the grille) Make sure the micro switch cables are plugged in and have a clean connection. Not jumping to any conclusions, but a guess could be that the micro switch went bad? Give me a call if you have any questions. Im here until 6pm.
Thanks again!
hexy2772
11
07-24-2002 06:55 PM
Audi_2000_1.8t
06-08-2001 01:40 PM
