Sponsored by:
Sponsored by:
D4 A8 Fuse Block Info
Old 07-08-2011, 11:24 AM
Big Hank's Avatar
Default D4 A8 Fuse Block Info
Does anyone know if any of the driver side fuse block slots eventually cut off power? ie:works off of the key switch
It appears that every fuse slot in both blocks are always hot which is a problem for my hardwire radar dector harness. I know there is a block on the passenger side as well as the rear but that would be a pain to wire to.
What I am hoping for is at least one of them eventually shuts off after a set amount of time for some of the electronics.
Old 11-08-2011, 03:43 PM
Eric (Plug Guy)'s Avatar
Dealing with same issue. Working on passenger side block - all unswitched. Crap.
Where are the switched fuse blocks???
Old 12-25-2016, 05:33 PM
diamondmit's Avatar
Default Did you guys ever find a switched fuse or wire? I've installed...
...LED lights on the lower front bumper aligned with the radar pods and just need to power them with a switched source.
Thanks,
David
miwim
TT (Mk2) Discussion
12
02-20-2009 06:53 AM
RaiderTT2001
01-26-2007 10:34 AM
2003a4MT6
11
05-21-2006 02:41 PM
HooliganDrew
05-03-2002 10:19 AM
Ray Calvo
11-13-1999 05:45 AM
Quick Reply: D4 A8 Fuse Block Info
