Sponsored by:
Sponsored by:
Headlight washer
Old 01-22-2017, 03:56 PM
jdemocker's Avatar
Default Headlight washer
Does anyone know if its possible to disable the headlight washer on a 13 A8l 3.0l?
Old 01-23-2017, 01:55 PM
Jack88's Avatar
Disable it? Check my signature for VCDS mods, if you have a Rosstech cable, you can use that to adjust how often they come on, maybe even off entirely, in terms of coming on in conjunction with the regular ones. Otherwise, nothing you can do.
Old 03-26-2017, 10:07 PM
major_major's Avatar
I would really like to know the answer to this question as well. According to some Q5/Q7 threads, the vag-com code is as follows:
1) VAG-COM Disable Headlight Washers
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 18
Bit 0 - Remove check mark (1 = headlight washers installed)
Can someone with a vag-com cable try this and let me know if it works. If so, then I'll buy the cable/software. Thanks.
Old 03-27-2017, 06:01 AM
cleex024's Avatar
just buy the obd11...its worth having as its much cheaper and can do everything the vcds can...i just bought one and love it...i used it to code windows up with remote, lower car, double beep when unlocking car, close trunk with remote, early correction with lane keep assist, and plenty more. its worth the $60.
Old 04-01-2022, 03:01 PM
Super-Duper User
A8L_New_England's Avatar
OBD11 ...if you don't mind buying "credits". That ruffles my feathers a bit, and it also requires an internet connection. If you do a lot of tinkering or want to do any long coding, it's VCDS or XTool (or OBD11 Pro).
pfgray2008
Q5/SQ5 MKI (8R) Discussion
11-05-2015 12:54 PM
dlmmail18
Audi A3 / S3 / RS 3 MKII
12-16-2014 05:10 PM
lenny48
12-20-2010 08:19 AM
lawrence allroad
Audi allroad
11-03-2009 09:09 PM
lowbee
VAG-COM Discussion
04-17-2006 08:29 AM
Quick Reply: Headlight washer
