Lowering confirmed via VCDS
#21
What exactly is the "benefit" to lowering the car - just so the tire surround is closer to the tire and it looks more filled?
By lowering the car - doesn't that also stiffen the ride?
#22
Generally it doesn't affect ride quality much, unless you make a significant change. It's an aesthetic modification, it doesn't help anything. I thought of lowering mine, but I decided to leave it so I didn't have to worry about pulling in and out of drives.
#23
On D3 where this first came out, I would call it purely aesthetic within reason. From playing with it some there, I found beyond about 10mm of dialed in drop, it did start to affect ride quality on poorly maintained freeways, especially in the most aggressive mode (Dynamic, aka Sport).
#24
On D3 where this first came out, I would call it purely aesthetic within reason. From playing with it some there, I found beyond about 10mm of dialed in drop, it did start to affect ride quality on poorly maintained freeways, especially in the most aggressive mode (Dynamic, aka Sport). No personal experience on D4 S8 but suspect the same sort of results likely apply given system set up from D3 to D4 remains very similar.
#25
with air suspension systems there are no benefits other than looks with that said I'd too would like to lower mine once summer comes around and I slap a set of rims on
#26
there are more benefits to lowering a car other than for looks but those benefits are normally with coilovers having dampening systems or with struts and springs.
umm anyway back to answering the original question on benefits of using vcds to lower your D4 A8 or S8 or that of any car - air suspension or conventional :
up to 35% of a car's aerodynamic drag can come from the bottom of the car - (I don't know the exact number on the Audi) - lowering helps improve that - which is why every car with dynamically leveling suspension lowers itself at high speed
lower center of gravity = improved pitch and roll comfort (dive and squat and lean)
for those reasons every car sold in Germany is aboiut 10mm lower than the same car sold in the US.
#27
[QUOTE=audisession;24904735]????
LoL. i had aftermarket air on an M45 and tampered with factory air on a LS600HL. What I meant was There's a lot of flex on those cars with the air suspension I either put in or it came with and not the same as having coilovers or struts when talking about lowering it
#28
[QUOTE=Jlam1017;24904736]
thanks for clarifying...?
Still doesn't make sense how you can say lowering makes no difference - you can't re write physics
#29
[QUOTE=audisession;24904755]Technically speaking, it does affect aerodynamics, but I don't think that was what the original asker was looking for. It doesn't improve handling, and the improvement on gas mileage seems negligible. So, from a practical standpoint, it's an aesthetic change. So, stop giving people crap.
#30
[QUOTE=Jack88;24904782]
technicaly it affects both aerodynamics and handling because a lower center of gravity affects pitch and roll (Front to back and side to side movement) which directly affects handling
unless you have instrumented proof - non of us can claim to what degree it affects handling - so to say it's purely "aesthetic" is not accurate
as far as the "crap" you mentioned - please stop spewing crap - you have nothing to back up your statements and your "butt accelerometer and handling circuit" doesn't count.
