Miles between oil changes
#11
And regardless, as I mentioned earlier, the only real change in here schedules occurred only in MY 2017 where they got rid of the first 5K miles step and shifted everything to even 10K steps. No matter which year I post up, they will otherwise read essentially the same from 2011 to 2016--for a given motor.
#12
Thank you for the corrected info. I did purchase Audi Care Plus. I'm wondering if this was mistake now vs just taking to a good independent shop. The dealer was giving me information that seems not to be correct.
#13
Not sure how you find a so called good independent shop. These cars are expensive enough that I am willing to potentially "overpay" to have someone who works on nothing but Audis service my vehicle. The thought of a non Audi service provider screwing something up not worth the savings to me. If they damage something it would void any warranty claim as well. regards. Ned.
#14
I agree. I purchased it for piece of mind. Just kind of disappointed the plan was misrepresented. Like the need for 5k oil changes, just found out they cover brake pads but not rotors, and who knows what else is excluded. It's not a big deal just the typical dealer sales tactics I guess. I have used yelp and found multiple German car specialty shops with ratings far better then any Audi dealer in my area. The problem that can arise is if something got messed up they would deny the cpo coverage.
#15
Suggestion: go back to original dealer. Say (nicely) you would like to come in to talk to service manager, and maybe sales guy or manager. As an A8 customer, you tend to get better white glove. Then have a do over on exactly what you bought, what is covered and so on. If for some reason you get run around, call the Audi 800 number and get to an A8 type representative--business class, not coach if you will. Sometimes you may just get the call center script stuff, but other times they can and do intervene to make things right.
You could also have some extra priced plan in here I can't make sense of. Thus, the brake info for std. Audi or std. AudiCare (which I got for my CPO) isn't right either. Neither pads nor rotors are covered. Same with no wiper blades or tires. But, if some other needed work causes them to be screwed up, sometimes they get covered. An obvious (super long shot) one is if a brake caliper fails and fluid goes on pads, you get new pads. Or if pad physically falls apart and eats rotor, should be same result. Sometimes owners who make enough noise about squeals and such can get new pads too, or rarely rotors. But normal case is not covered for general wear. Still, you need to figure out if you were unsold some add on dealer service plan that is coming into play here.
In general, I would use your AudiCare and then fill in extra oil changes around it. A competent indy can certainly do oil changes and sometimes a lot more. But dont go to the Jiffy World crap either. All time best (worst...) post ever was the poor owner who later found the Jiffy Lube guy couldn't figure out the lower engine cover so literally demo sawed it to get to the filter and drain. Yikes! Meantime, you do need to use the factory recommended oil, which means 502/505 compliant usually. Mobil 1 0W40 is an easy example of that, or Castrol 5W-40US European Formula. Lots of others too. A good indy will know what that means. A corner gas station or Jiffy Lube will look at you like you are from Mars. And to be clear, same kind of specs apply to most Euro vehicles--Merc, BMW, Mini, Jag, VW, Porsche, etc., so it isn't just an "Audi" thing. Also know the dealer oil (Castrol Professional Grade typically) has a uv dye in it so they can check. But you are allowed to have any service you want, as long as per spec. Thus if indy, keep receipts and documentation just in case.
Meantime you need to get past know nothing sales person and finance dept. types to the service professionals. You may find that more satisfying, even at same dealer. But first, you do need to understand what you were even sold (or promised). More where a manager comes in--the one with the size 12's for good measure.
#16
Funny about monitoring oil quality
I was under the impression that the car monitors the oil quality and calculates when it needs changing. You can see it in the MMI and if you drive hard the remaining milage will go down. I know there are a few settings in vcds where you can set some of the parameters that go into the calculation.
Having said that I still change the oil every 12mth's or 15,000km which ever comes first. I usually get a range of 26,000km a few weeks after an oilchange.
I am in Europe and if I remember correctly the US market don't have the same long life oil spec.
Automobile mfrs cannot by American law require a specific brand to ensure warranty coverage unless they provide the product. Warren/Magnuson Act, IIRC.
#17
Yeah, I would never take her to a jiffy lube or this sort of shop. Well rated German specially shops is the only place I would go. I also was not told that Audi care is a non refundable program... lol. Oh well, I guess it is what it is.
#18
Still recommend you have a further discussion w/ dealership (or if need be Audi USA) as outlined in my prior reply #15.
#19
I've heard horror stories of a lube shop stripping the threads on the oil filter connection! That would be frightening on any car let alone a warrantied car. Regards. Ned.
#20
And for the confirmation the whack stuff really happens--at least someone else's nightmare--see: Lazy Idiots At Lube Shop Cut Hole In Audi S4's Aero Pan Instead Of Removing It Oops, not Jiffy Lube, but same pathetic idea...
