New to me 2016 A8L 4.0T Sport
#12
One of the custom fit reflective windshield covers work well. I would guess a good 20 degrees cooler. With all the shades up,sunroof blind pulled, but sun roof tilted. I already have a dark tint so it's like sitting in a cave till you get out.
Not sure about the % of tint, but you can't see in from outside at most angles.
But I'd say you already know these tips living in Nevada
#13
its not just when parked... I was sitting a red light and the sun was cooking me through the windshield. Side windows were fine. I may add tint to the sunroof as well...
I had a custom folding sun shade in my S65. That helped greatly when parking the car. Cooler temps and saved the leather covered dash...
#14
Next I've been researching the VCDS codes that let you change things that aren't enables from the factory...
* Needle Sweep
* Operate windows from the remote
* Play DVD while in motion
I would also like to find out if I can change the defaults for a few things...
- My car has an Auto feature for the LED headlights that's not default to being active
- I would like the radio to display the current channel as default and start in the Preset List
- I would like to be able to push button start the car without needing to apply the brake pedal
* Needle Sweep
#15
Well, those first three are easy enough. As for the last three, that's different. I don't know what auto feature you are refering to, the only auto LED's I know of are set by the headlight switch. For the radio and push button start, I don't believe those things can be set as you wish.
#16
#17
Does anyone know what the diameter of the exhaust is that goes into the center suitcase style resonator? I would like to bring my own X pipe with me when I have it removed.
What is our exhaust made of? Stainless steel or mild steel?
#18
EKTA parts diagram (for 4.0T) probably gets you the answer on diameter if you look at the surrounding connection fitting clamping points (##6 and 7).
#20
Yes. Goes back to D3 when W12 and S8 had them. Now even my four banger Hybrid has one. Audi uses them more as a power/tuning thing, but maybe the opposite of what you expect. That is, they close to increase back pressure, which helps in low RPM torque and then probably fuel economy a little bit too. A little more complicated w/ turbo's probably, but the general principle. Sound is then a function of how aggressive exhaust is. But given latter is designed luxo barge quiet, you don't hear much. On my D3 I unplugged them for a while when their "fail" position was open, but it didn't change sound much either. A little bit on moderate off idle acceleration, but otherwise not really.
