Normal for 4.0T to run "hot"? Big concern
#11
I have a RS7 and an A8 4.0, and cooling fans run immediately after shutting the motor. Only in the cold of deep winter, do the fans either not run or run for a short period of time. The heat emitted, I do not feel any different from my other performance vehicles. I have not detected any smell.
#13
Are the cooling fans fairly loud? Now that I'm thinking about it I don't hear anything when I shut off the car. I will have to listen for it later when I take it for a ride.
Regarding the other advice, I had a good indie that I used to have service my '05 A8. I will pay him to give a thorough inspection before my 45K service.
#14
#15
I have not really stopped mine so far in extremely hot weather and/or when badly heat soaked. I would say the typical sound is modest to moderate. Obvious if parked in a garage. Can blend more into noisy environments outside but noticeable most times hardly even listening for it. Fans are not running close to top speed, but also not down at the lowest baseline speed like when you start it cold with A/C on.
#16
Ok, I suspect my problem is my fan doesn't run after stopping the car. Tried it today, it is 98 outside, drove for 20 minutes, pulled into my garage and turned it off. Dead silence. Short video from the moment I turned it off below. Curious what damage this could have caused?
August 14, 2016 - YouTube
#20
My 17 does the same thing...... fans come on right after a drive when parked...... I try to keep my garage open until they stop.....3-5 min Outside of that, there is no indication the car runs hot while under operation
trevakaed
Audi A3 / S3 / RS 3 MKII
05-14-2016 07:19 AM
BlingOnMyWrist
02-08-2012 10:17 AM
rohulp
04-27-2011 09:58 AM
golfindaily
11
07-14-2005 05:06 AM
-M3=Lunch-
20
01-25-2005 02:13 PM
