Porsche info
Porsche info
A lot of people here seem to have or had a 911 at some point. I love my A8 and will probably get another after this one, but the car nut in me needs another outlet for my enthusiasm. I think it's about time to finally start looking for the 911 that I have always known I would own one day.
I have not decided on a budget yet, but I'm not looking to spend a lot on something that will be a grocery getter on weekends, and a toy when I don't have to haul my kids around. I'm leaning towards a decent 993 or an earlier 997. Just looking around, the cost of a 2008 911s is probably going to be as high as I am comfortable with for my first 911.
What is the 911 equivalent to this forum? I think I need to lurk for a while and learn as much as I can from owners before I can make an informed decision on an appropriate model/price for my needs.
Rennlist is the most active and comprehensive collection of 911 forums I am aware of. Btw I owned a 997 (2008) Carrera for several years. A lot of fun, but I would not recommend the Tiptronic transmission, which was the only automatic available on the 997 until the highly improved PDK appeared around 2010. It's a real slush box compared to the PDK that replaced it, and it saps a lot of the car's soul, at least in my humble opinion.
Also, 993s are fantastic and will almost definitely hold their value better than a 996 or 997. But they aren't cheap. You will get the most bang for your buck in a 996. You can probably find a light speed quick 996 turbo for a decent price. Good luck.
Thanks for the information, I am going to check out both of those forums. Today I checked out a 996 targa that was just traded in at the local Porsche dealership. The price is certainly a selling point, but I am not sure I can get past the abomination they call headlights on the 996.
The salesman told me that they are reluctant to take 997s in trade because the price is beginning the slide to bottom, and it's real easy to take a bath on one. He said the 996s have reached bottom so they are not as risky from the dealership's perspective. Hopefully I can get a good deal on a 997 and save the 993 and eventually 930 for when I am a seasoned 911 owner.
+1 on rennlist.com
Also check out a magazine called 'Excellence'
EDIT: Pratfall's suggestion of 996 Turbo is a good one... Basically you get the Mezger designed engine but in a slightly cheaper package with awesome specs. And if you plan on hauling kids they will fit in the 911 back seat.
When you first drive your 911 take the time initially to get comfortable with its driving dynamics. You will be coming from an A8 which is about as stable as it gets to a vehicle with about sixty percent of its weight over the rear axel, and depending on the vintage it may not have stability control. The rear end can spin out. The rule for a 911 is never, never hit the brakes in a turn, and don't even lift off the gas if you are aggressive in a turn. Brake if you have to before the turn and then power thru the turn. If the tail slips out, steer in the direction of the slide, and get on the gas hard. This tendency of a 911 is actually what makes it so much fun to drive because you can influence the rate of turn with the gas pedal. I used to practice by going into a clover leaf off a highway fast, then back off so the tail went out a bit, then give it gas to correct things. Do that a few times and you won't be taken by surprise.
I realize this probably comes across as lecturing, but I think it is important and I gave the same lecture to my son. Enjoy, Mike
This is the type of " lecture" everyone seriously considering a 911 should be required to have before getting behind the wheel of one. I may even purchase some track time and a 911 instructor after I get the car.
