Sponsored by:
Sponsored by:
Right side access control codes?
Old 10-06-2014, 09:05 AM
  #11
jakematic's Avatar
Originally Posted by A 8
is there a way to find out the color coding of the wires relevant to the sensor?
erWin Portal
erWin is $35 US per day and has all factory repair manuals and wiring diagrams.
They are in PDF format and you can save them to your computer.
Old 10-19-2014, 11:39 AM
  #12
synchrocnc's Avatar
Hello,
I have had my doors looms apart to do a B&O retrofit and it looks like the right rear is grey/green and right front was green/grey on my car (2010 4.2tdi RHD), the other side of the sensors go to brown which would be ground. they both seem to then go to the J393 convenience system control unit in the boot.
The sensors do fail and my car has had 2 already.
Good luck.
Old 10-19-2014, 10:51 PM
  #13
A 8
A 8's Avatar
Originally Posted by synchrocnc
Hello,
Good luck.
Great info, thanks! When they fail, do you have to replace and repaint the handle?
Old 10-21-2014, 11:17 AM
  #14
synchrocnc's Avatar
If you go to partsbase.org it looks like they are a separate part inside the handle, mine were changed under warranty so I'm not sure. You can get the handle out without taking the door apart using a Torx screwdriver, I.m sure there must be a video on the net somewhere for this.
Old 10-22-2014, 08:07 AM
  #15
A 8
A 8's Avatar
Again very valuable input! There are a few vids on other cars and I deduced the D4 A8 would be similar and found the torx screw but also found out that the control unit could damage the sensor if faulty. As they've been changed once already at only 3000 miles I may need to change the control unit at the same time.
ohsigmachi
03-29-2016 05:04 AM
Baikal
09-11-2015 10:05 AM
ajg617
09-06-2015 07:23 AM
stormchaser1967
09-02-2015 09:02 AM
ECS Tuning-Audi
09-01-2015 12:25 PM
Quick Reply: Right side access control codes?
