Right side access control codes?
This may a bit to detailed and nerdy if you want but I will give it a try, I am getting fault codes of my VCDS and issues with keyless go. The codes are random in terms of short to ground and open circuit etc relating to the door sensors on the right side doors. When I bought the car @ 7500 miles I tracked that they had changed both right side doors. At the time I just made sure the door change was not due to major body damage but now it seems they were trying to fix this issue.
My question then, anyone know what common point the right side doors electrically connect to or given: 03286 - Sensor for external handle right front 008 - implausible signal - Intermittent and 011 disrupted signal (free translation), after the doors (and sensors) have been replaced what would be the next point of replacement be?
The car still have guarantee but I don't want a mechanic messing up the car and was hoping for some insights or help where to find the next logical place to check?
Thanks, the loom's are part of the new doors and are in perfect condition as far as I can tell.
My VCDS is in Swedish but a google translate gives me this:
Address 05: Access control Labels:
Control No. :
Component and / or Version :
E- coding :
WorkShop :
VCID : 5599BDADAC7F43B6981-8000
3 Fault Found :
03286 - Sensor for exterior door handles , front right
008 - Excessive signal - Intermittent fault
frozen data:
Error Status : 01101011
Felprioritet : 2
Error frequency : 1
Reset counter: 11
Mileage: 22878 km
Time Display: 0
Date: 28/09/2014
Time: 11:55:20
00193 - Sense of touch : ext. right rear door handle ( G418)
011 - break
frozen data:
Felprioritet : 2
Error frequency : 1
Reset counter: 8
Mileage: 22830 km
Time Display: 0
Date: 09/27/2014
Time: 10:00:03
011 - break
frozen data:
Raw , Index / Key error : 211,023,012
Raw , Index / Key error : 211,027,012
Raw , Index / Key error : 211,028,000
Raw , Index / Key error : 182,022,000
Raw , Index / Key error : 182,023,000
I just cleared the codes getting the keyless go working again and trying to figure out if it is relating to a few other codes I am getting. Traveling in the car tomorrow on a 2 day journey so likely it will be back, will post back a fresh and complete autoscan in a few days.
Control No. :
E- coding :
WorkShop :
3 Fault Found :
frozen data:
Felprioritet : 2
Error frequency : 1
Reset counter: 11
Mileage: 22878 km
Time Display: 0
Date: 28/09/2014
Time: 11:55:20
011 - break
frozen data:
Felprioritet : 2
Error frequency : 1
Reset counter: 8
Mileage: 22830 km
Time Display: 0
Date: 09/27/2014
Time: 10:00:03
011 - break
frozen data:
Is this what you mean by an auto scan? Sorry about the Swedish but its #5 thats the issue, access control saying fault 0010? I have a few other issues as well but they don't seem to affect any functions in the car so far.
Chassityp: 4H (4H0)
Skanna: 01 02 03 05 06 08 09 0E 10 13 15 16 17 18 19 1B 22 28 34 36
3B 3C 42 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 84 85 88
89 8B 8E 8F 90
VIN: WAUZZZ4H1AN000
01-Motor -- Status: OK 0000
02-Automatväxel -- Status: OK 0000
03-Bromselektronik -- Status: OK 0000
04-Styrposition -- Status: OK 0000
05-Behör.kontroll -- Status: Felfunktion 0010
06-Stolminne pass. -- Status: OK 0000
08-Klimatanläggning -- Status: OK 0000
09-Elektron. elcentral -- Status: OK 0000
0E-Mediaspelare 1 -- Status: OK 0000
10-park/styr-hjälp -- Status: OK 0000
13-Distansreglering -- Status: OK 0000
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: Felfunktion 0010
18-Extra/p-värmare -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-aktiv styrning -- Status: OK 0000
22-AWD -- Status: OK 0000
28-Klimatmanövr. bak -- Status: OK 0000
34-Nivåreglering -- Status: OK 0000
36-Stolminne förare -- Status: OK 0000
3B-Sensor-elektr. -- Status: OK 0000
3C-Filbyteshjälp -- Status: OK 0000
42-Dörrel. förare -- Status: OK 0000
46-Komfortcentral -- Status: OK 0000
47-Ljudsystem -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
53-Parkeringsbroms -- Status: OK 0000
55-Räckviddsregl. ljus -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV-tuner -- Status: OK 0000
5F-Inform.elektr. 1 -- Status: Felfunktion 0010
62-Dörr vä. bak -- Status: OK 0000
6C-Back-kamera -- Status: OK 0000
6D-El Bagageutr. -- Status: OK 0000
6F-Komfortel. II -- Status: OK 0000
72-Dörr hö bak -- Status: OK 0000
81-växling -- Status: Felfunktion 0010
84-Nattseende -- Status: OK 0000
85-installerad kamera -- Status: OK 0000
88-Panel säte förare -- Status: OK 0000
89-Panel säte passagerare -- Status: OK 0000
8B-Adaptiv farthållare 2 -- Status: OK 0000
8E-Bildbehandling -- Status: OK 0000
8F-bältesspänn vä fram -- Status: OK 0000
90-bältesspänn hö fram -- Status: OK 0000
Chassityp: 4H (4H0)
89 8B 8E 8F 90
VIN: WAUZZZ4H1AN000
I got the English version, after all support and documentation are all in English. After code clear the keyless go works until I start and stop the car, after that it don't and I have the code. I did mess around the cables per your suggestion and it seems the error is now "stable" Is there anyway to "soft" test the cable connection using VCDS or do I need to take the door apart, find the right cables and measure resistance?
Posting the full autoscan:
Sunday,05,October,2014,11:02:58:32277
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WAUZZZ4H1AN0008** License Plate:
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 18 19 1B 22 28 34 36
89 8B 8E 8F 90
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
84-Night Vision -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (------CDRA) Labels: None
Part No SW: 4H0 907 560 HW: 4H0 907 560
Component: 4.2l V8/4V H05 0004
Revision: N5H05---
Coding: 0106000C291F0268
Shop #: WSC 00477 128 36032
ASAM Dataset: EV_ECM42FSI0114H0907560 001006
ROD: EV_ECM42FSI0114H0907560.rod
VCID: E7E507651E134126BA7-80B2
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4H1 927 158 E HW: 0BK 927 156 K
Component: 0BK 42 FSIRdW H03 0006
Revision: --H03---
Coding: 001111
Shop #: WSC 02152 128 182615
ASAM Dataset: EV_TCMALX51011 001011
ROD: EV_TCMALX51011_AU64.rod
VCID: 325326316551748E5D9-8067
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 A HW: 4H0 907 379 A
Component: ESP PREMIUM H08 0151
Revision: -------- Serial number: --------------
Coding: 44FAA200225F4500E300
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_ESPPremi 004012
ROD: EV_ESPPremi_AU64.rod
VCID: 30572C396B5D469E2BD-8065
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 DB HW: 4H0 907 064 L
Component: BCM2 2.0 H13 0510
Revision: 00002001
Coding: 05070001000000000000
Shop #: WSC 25577 142 91831
VCID: 6CEFF8498FF5E27E575-8039
Subsystem 1 - Part No SW: 4H0 905 852 A HW: 4H0 905 852 A
Component: J764 ELV MLB H37 0042
1 Fault Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 23152 km
Time Indication: 0
Date: 2014.10.05
Time: 10:43:57
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 A HW: 4H0 959 760 A
Component: MEM-BFS H07 0114
Revision: AA000000 Serial number: 00001001371056
Coding: C008320085043201010021212121312131313333283333
Shop #: WSC 74501 143 179126
VCID: 3151293D68574F96243-8064
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 4H0 820 043 E HW: 4H0 820 043 E
Component: Klima 4 Zonen H12 0061
Coding: 481101B88C
ASAM Dataset: EV_AirCondiFront 001012
ROD: EV_AirCondiFront_AU64.rod
VCID: 2273D67135B1E40EAD9-8077
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 D HW: 4H0 907 063 D
Component: BCM1 2.0 H09 0083
Revision: 15009001 Serial number: 00000000524142
Coding: 0200201050B49FF1FB810004A0001908009CC3088A00012180 0008002100
Shop #: WSC 02447 128 28888
VCID: 2961C15D40873756EC3-807C
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 091120 H32 0032
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 410 HW: 4H0 907 410
Component: EHL2 V07.03 H30 0020
Subsystem 5 - Part No SW: 4H0 907 705 H HW: 4H0 907 705 C
Component: EVLS-SG H07 0275
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H01 0001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 E HW: 4H0 035 108
Component: DVDCAlpine H42 0190
Revision: AA001001
Coding: 010000
VCID: 2273D6713DB1E40EAD9-8077
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 C HW: 4H0 919 475 C
Component: PARKHILFE ACC H05 0011
Revision: 11001001 Serial number: 44830930802518
Coding: 300902
ASAM Dataset: EV_AU64XParkiAssis2 005003
ROD: EV_AU64XParkiAssis2.rod
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 561 A HW: 4H0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Coding: 3604010201
Shop #: WSC 74501 143 91550
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X.rod
VCID: 2961C15D48873756EC3-807C
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 HW: 4H0 959 655
Component: Airbag10.43 H11 0012
Revision: -------- Serial number: 003CM0011ZTH
Coding: 30314246313130303033554A304C34483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001008
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: F3DD63355ACBBD8616F-80A6
Crash sensor for side airbag; driver side:
Serial number: 3572DRB400008C44694X
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB400008C4461AW
Crash sensor for side airbag; rear driver side:
Serial number: 3515JRB405C70PNCKPD2
Crash sensor for side airbag; rear passenger side:
Serial number: 3525JRB405C70PNC8859
Crash sensor for front airbag; driver side:
Serial number: 3554VRB404U70PNCE9RQ
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB404U70PNC694$
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 A HW: 4H0 953 568 A
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815ILI00007
Coding: 00003C
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Component: E221 - MFL H06 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 830 E HW: 4H0 920 830 E
Component: TBenRDWACCNV- H29 0185
Revision: 18409109 Serial number: 658151209593405
Coding: 13060800BF000008000000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 2765C7655E930126FA7-8072
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0224
Serial number: 1120823000299
1 Fault Found:
1048578 - No Basic Setting
B2010 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 23148 km
Date: 2014.10.05
Time: 10:26:57
Address 18: Aux. Heat (J364) Labels: 8R0-265-105.clb
Part No SW: 4H0 265 105 HW: 4H0 265 105
Component: Standheizung H20 0210
Revision: 34003004 Serial number: 20091208234009
Coding: 4D1100
VCID: DFF51F85CE4309E6427-808A
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 C HW: 4H0 907 468 C
Component: J533--Gateway H07 0175
Revision: -------- Serial number: 00000000003904
Coding: 00C103
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_GatewUDS 001021
ROD: EV_GatewUDS_AU57.rod
VCID: 3151293D60574F96243-8064
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0130
Serial number: 00000000005640001530
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 HW: 4H0 907 144
Component: DYNAMIKLENK. H06 0070
Revision: 50001005 Serial number: --------------
Coding: 8B0000
VCID: E5F90D6DEC1F533688B-80B0
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 HW: 4H0 907 163
Component: 4 Wheel Drive H11 0005
Serial number: 000112090001001
ASAM Dataset: EV_AllWheelDiffeQSPFR 003017
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: E6FB0A611919582E811-80B3
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H11 0062
Coding: 0100000000
ASAM Dataset: EV_AirCondiHeck 001037
ROD: EV_AirCondiHeck_AU64.rod
Address 34: Level Control (J197) Labels: Redir Fail!
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H14 0099
Coding: 008006
Shop #: WSC 02152 823 28888
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_AU64.rod
VCID: 2E6B32417169506E391-807B
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H07 0114
Revision: AA000000 Serial number: 00001001373033
Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 A HW: 4H0 907 637 A
Component: SARA 6D red H02 0011
Revision: -------- Serial number: EJ1370000RUF000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 2D69354D7C6F2B7600B-8078
Address 3C: Lane Change Labels: None
Part No SW: 4H0 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH02 0100
Revision: 00H02000 Serial number: 6PZ 010 287-00
Coding: 0000101
VCID: EDE9754DF4EF6B76C0B-80B8
Subsystem 1 - Part No: 4H0 907 568
Component: J770 SWA Slave H01 0100
Subsystem 2 - Serial number: 6PZ 010 287-20
Subsystem 3 - Serial number: 5F04.12.0900H010003CH11469ÿ
Subsystem 4 - Serial number: H11469ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 E HW: 4H0 959 793 E
Component: TSG FA H02 0162
Revision: -------- Serial number: 0000102530055
Coding: 011F1E205E0062C202000007
VCID: 3B4D0B15BA1BB5C68EF-806E
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0124984557
Coding: 011A0E2000397585B33007F28E000000000000000000000000 0000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0070
Subsystem 2 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.022 H06 0004
Coding: 001F00
Subsystem 5 - Part No SW: 4H0 947 135 K HW: 4H0 947 135 K
Component: Dachelektroni H11 0070
Coding: 010000
Subsystem 6 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS009 H05 0004
Address 47: Sound System (J525) Labels: None
Part No SW: 4H0 035 223 HW: 4H0 035 223
Component: BOSE G3 D4 H07 0050
Revision: CI007500 Serial number: 00000000000934
VCID: DB8D2B95DA5B15C62EF-808E
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0162
Revision: -------- Serial number: 0000102493448
VCID: 3A430E11B5218CCE959-806F
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000342311
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 2A633E514D813C4EE59-807F
Address 55: Xenon Range (J431) Labels: 4H4-907-357.clb
Part No SW: 4H4 907 357 HW: 4H4 907 357
Component: ....AFS13.... H01 0091
Serial number: 091217-0004-039
Coding: 11116F33F91AFA00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste.rod
VCID: EFD56F4536E39966F27-80BA
Left Headlamp Power Output Stage:
H02 0003
Right Headlamp Power Output Stage:
H02 0003
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4E0 035 061 L HW: 4E0 035 061
Component: Radio U DAB H45 0085
Revision: AB001007 Serial number: 014AC0A7502150
Coding: 010103010000000001
VCID: 247FD06927A5EA3EDF5-8071
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4F0 919 129 G HW: 4F0 919 129
Component: HybridTV-DVB H06 0550
Revision: R0060000 Serial number: 76300802563402
Coding: 01010000
VCID: 30572C39635D469E2BD-8065
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 670 N HW: 4H0 035 670 N
Component: H-BNT-EU H44 0526
Revision: -------- Serial number: 179I00C7503527
Coding: 020100000001FBEF75168B1E00000003000001000000000000
VCID: 2F552F457E635966327-807A
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4F0 910 393 R HW: 4F0 862 393 E
Component: BTHS H24 0620
Subsystem 3 - Part No SW: 4H0 919 604 B HW: 4H0 919 604 B
Component: DU8 D4 SV NB H44 0021
Subsystem 4 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Subsystem 5 - Part No: 8R0 060 961 C
Component: CD-Database 3638
2 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:29:18
Freeze Frame:
Voltage: 12.10 V
03787 - Rotation Mechanism for Display Module Front
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 6
Fault Frequency: 4
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:26:59
Freeze Frame:
Voltage: 11.80 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0162
Revision: -------- Serial number: 0000102423614
Coding: 010F1E20400062C202000007
VCID: 3941111DB02787D69C3-806C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H03--- Serial number: 525PA8-J9ZD05J
Coding: 1021002
VCID: E5F90D6D2C1F533688B-80B0
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 F
Component: HDSG-Modul H11 0036
Revision: 09145325 Serial number: 333900021
Coding: 0210044000
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3B4D0B15B21BB5C68EF-806E
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000001822
Coding: 000000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: E3FD1375EA2B2D0666F-80B6
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0162
Revision: -------- Serial number: 0000102423694
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H1 927 731 HW: 4H1 927 731
Component: GSM-LL H07 0083
Revision: 0L0D4009 Serial number: SN091128 0012
ASAM Dataset: EV_GSM2x3Mono 001017
ROD: EV_GSM2x3Mono.rod
VCID: EAE37E510D017C4EA59-80BF
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 D HW: 4H0 907 547
Component: NV-ECU-Gen1 H08 0022
Serial number: 0K84AE40001130
Coding: 1101
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H06 0006
Serial number: 00000000000934312911
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4H0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H20 0016
Revision: -------- Serial number: 262130025421000
Coding: EC060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 A HW: 4H0 907 182 A
Component: IVB H03 0027
Serial number: 00443894081801
Coding: 764FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2867C459538D0E5EF3D-807D
Address 89: Multicont. Seat Pass. (J872) Labels: None
Serial number: 00443894084601
Coding: 364FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 541 A HW: 4H0 907 541
Coding: 3604010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851) Labels: None
Part No SW: 4H0 907 107 HW: 4H0 907 107
Component: BV-SG H24 0008
Serial number: 000040052112097
Coding: 01A08201
ASAM Dataset: EV_BVS 001007
ROD: EV_BVS.rod
VCID: E4FF1069EF252A3E9F5-80B1
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H04 0070
Coding: 0066F609031F037E070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H04 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: F0D76C392BDD869EEBD-80A5
End ---------------------------------------------------------------------
89 8B 8E 8F 90
Revision: N5H05---
Revision: --H03---
Coding: 001111
Revision: 00002001
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 23152 km
Time Indication: 0
Date: 2014.10.05
Time: 10:43:57
Coding: 481101B88C
Coding: 0045F7
Coding: 025523
Coding: 020300
Revision: AA001001
Coding: 010000
Coding: 300902
Coding: 3604010201
Coding: 00003C
ROD: EV_RBD4K.rod
Analog_clock:
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 23148 km
Date: 2014.10.05
Time: 10:26:57
Coding: 4D1100
Coding: 00C103
Coding: 8B0000
Coding: 0100000000
Coding: 008006
ROD: EV_SARA.rod
Coding: 0000101
Coding: 001F00
Coding: 010000
H02 0003
H02 0003
Coding: 01010000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:29:18
Freeze Frame:
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:26:59
Freeze Frame:
Voltage: 11.80 V
Coding: 1021002
Coding: 0210044000
Coding: 000000
ROD: EV_Ambie.rod
Coding: 1101
Coding: EC060000
Coding: 764FF2
Coding: 364FF2
Coding: 3604010201
Coding: 01A08201
ROD: EV_BVS.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
Thank you so much for the full scan.
There is almost always something else in there that is of interest.
I'm not sure if there are any output test available, but look in the module in VCDS.
There probably is a measuring block though to test it.
These vehicles use UDS/ODX protocol so it may not be a numbered block like traditional, it's likely a pulldown in the menu.
I was concerned about 17, but that appears to be the clock - I'd reset that DTC.
This has me more concerned though:
I would run an Optical Bus Diagnostic and see where the error is.
The MMI display seems to have a problem, but you probably knew that.
Most important is those battery voltages.
Was the scan done with the engine running or a battery charger attached ?
How old is the battery ?
3-5 years is average life, shortened by extreme environments....
Low voltages cause all kind of erratic things and in very worst case can damage modules.
Due to the huge number of modules we have I always scan with the motor running
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:29:18
Freeze Frame:
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:26:59
Freeze Frame:
Voltage: 11.80 V
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:29:18
Freeze Frame:
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 64
Mileage: 23148 km
Time Indication: 0
Date: 2014.10.05
Time: 10:26:59
Freeze Frame:
Voltage: 11.80 V
There was a pulldown and I ran it but vcds just sat there waiting and I got nothing back.
The optical databus issue was new actually, did not have that before. Engine not running and no charger. I was on my second scan which could explain the low voltage and why I get this error.
The clock issue comes back immediately after resetting the DTC, not sure what to do about it and the clock works just fine.
The display module pops up as it should all the time so not sure about that either.
I'll check the databus issue with the engine on.
The battery is 4 yrs but its an AGM battery and the car has the solar panel option so I think it should hold a bit longer but I will test it just to make sure.
Could it be that the door sensor is just broken and needs replacing, would that give me the same error?
It's possible the optical issue came from the lower voltage.
Battery is probably good but doesn't hurt to test.
I get nervous every time I see low voltages though
The clock may just need to be re-coded as is - go into coding and click Do it.
The sensor may just be bad.
Because it's now stable since you moved the wiring it leads me to think it's a bad connection though.
I'd try to trace out the wires and test as you suggested.
The bad news is that if I recall correctly a new sensor involves changing the handle, and they don't come painted
If we can't make any progress, a second opinion wouldn't hurt - see the forum link in my signature...
The battery is good and the optical databus isssue seems to be gone with the engine running.
I've concluded I probably need to get someone to take take the door apart and figure out the sensor and cables as you indicate..or is there a way to find out the color coding of the wires relevant to the sensor?
