System Faults
System Faults
I have a 2011 A8 with 55,000 miles and today when I was pulling into my garage I had a lot of warning lights come on. 1- air suspension system fault 2-ESP fault 3-TPMS. Please Help!!! Is this as bad as it looks? Thanks
I second what jakematic suggested. While I myself have not yet purchased VCDS, I plan to soon. With BMW I was coding and retrofitting for years so I know how useful it is to have dealer-esque tools at your own disposal.
Also - BMW's are notorious for throwing random codes where there are battery or charging system problems - feels right that Audi would be similar.
I have an A6 2012 with these same three faults that appeared suddenly. The Audi dealership here has not been able to sort this out. Did you manage to find out what the problem was? Would really appreciate if you could share your find.
Thanks
Thanks
2011 Audi A8 Fault Lights
Driving into work; I had no problems whatsoever. I sat down to drive to a training module 5 miles away; started the car- and got these warning lights.
Ought I go change out a battery and see if that fixes it?
So; a quick OBD2 connection pulled diagnostic code P0106 Manifold Absolute Pressure / Barometric Pressure Circuit Range / Performance Problem.
Do I read that this is a sensor in the box with the ECU and may just need to be replaced? Oh dear God I hope so.
So I am certain Audi is marking this up considerably and I'm a little taken aback by $170/hr shop rates... The codes were all being caused by an intake camshaft sensor. $82 from Audi and 2.5 hours to install. Could an intake camshaft position sensor cause those faults!? It doesn't even seem related.
I am having this same issue as Warren allen, but I am getting no basic setting fault for address 3b and address 34 is saying Active shut off. Would a bad yaw/combi sensor cause this fault?
