Turn signal problem
Turn signal problem
Hello, from yesterday I had a problem with my turn signal the right one (passenger side). When I unlock the car I saw that it wasn't working. Tried some more times and it was the same. After maybe an hour I saw it to blink but not so bright like the other one, then it wasn't working again. Now is the same sometimes works, sometimes not. Anybody had this problem?
Nope, never heard of it. Assuming it's just the front or back, step one is to check the connector for the turn signal and make sure the connector is clean. If both the front and rear turn signals are failing to work, I would say it's your stalk. If it were the flasher, it would either work or not, none of this weak stuff.
Sorry, I forgot to write that the problem is in the front blinker in the headlight. I gone to a service and changed the haedlights when I put the left one (which is working) on the right side it works perfectly, but the right one doesn't work on the left side. We have changed the moduls from the left to right headlight and it isn't working again. I think i should go to the offical servic of Audi.
RodBautista
09-24-2011 02:14 PM
