Sponsored by:
Sponsored by:
VAG-COM Mods for D4 A8
Old 04-21-2014, 10:36 PM
  #21
kgd_007's Avatar
Thanks for the info. The D4 seems easier than the D3. I have done the following.
Window open/close via remote.
Double chirp when unlocking.
Ability to enter Nav and Phone entries w/o warning screen.
Increase coming home from 20 to 60 seconds.
Enabled needle sweep.
I tried the signal blink one but don't believe it works with LED light option.
I tried changing the ability to rip songs from CD's to the HDD but couldn't find the option in hidden menu.
I enabled the battery level meter in the hidden menu but it didn't show up in any of the Car menus.
These were all on a 2011 A8L.
Kris
Old 04-16-2016, 03:38 PM
  #22
miked4's Avatar
Anyone know how to match a new key using Vag Com for the D4?
Old 04-16-2016, 03:54 PM
  #23
Jack88's Avatar
The answer is you can't. It needs to be done at the dealer, there has to be communication back to Ingolstadt.
Old 04-16-2016, 04:30 PM
  #24
miked4's Avatar
[QUOTE=Jack88;24800522]The answer is you can't. It needs to be done at the dealer, there has to be communication back to Ingolstadt.[/QUOTE
Ok that sucks but guess I'll be making an appointment. Thanks for the quick response!
Old 04-19-2016, 10:47 AM
  #25
tomulsas1@gmail.com's Avatar
anybody in St Louis, MO with a VAG COM? I'm looking to do a few tweaks like mentioned above. thanks
Old 04-26-2016, 04:00 PM
  #26
frybear's Avatar
quite often your mechanic will have a vag-com set up, mine does, doesn't charge me to make the changes. just a thought.
Old 04-28-2016, 02:45 PM
  #27
Thx. I picked up a Ross-Tech VAG-COM and did some mods today. Works great. the only one I can not get to work is lowering the suspension. I'm running version 15.7.1. Looks like the method in lowering the D4 A8 is different that what I found on the forums. However, I finally found where to do it. Issue is I get an error when I adjust the height in mm. I'm increasing the number like on the threads by 15mm but get the error "Request Sequence Error". Any clue?
Old 04-30-2016, 07:18 AM
  #28
John Cocktoasten's Avatar
are you using the rosstech method?
Ross-Tech: VAG-COM: Suspension Level Control Calibration
Old 04-30-2016, 09:10 AM
  #29
Well, I purchased the car used. Looks like it is already lowered via VCDS and that's why I get the error. The settings were already at 405 mm.
Old 08-18-2016, 06:14 AM
  #30
josephpallan's Avatar
Link to every VCDS code you may ever need-
90% of them work for a8 d4 as well
VCDS & Hidden menu: The complete list - Page 3
Golan Remi (10-12-2020)
Quick Reply: VAG-COM Mods for D4 A8
