VCDS tweaks for the A8
#81
I did make the recommended adjustments, although left the fog light one for the rear, since it does have rear fog lights, at least when equipped with LED headlights. As far as your auto open not working, Fez, no idea. Worked for me, don't recall there being any trick to it.
#82
Polizei! Internetwache! Thread Hijack in Progress!
Don't know what this means but looks scary.
We should have some stickers made just like this except with "AudiWorld.com" where it says "Polizei"!
#83
That's it, if that doesn't work after making the necessary change in VCDS, I don't know what to tell you.
#84
Variously,
1. go back in w/ VCDS and recheck settings.
2. Make sure you check MMI settings for the area too; used to be solely VCDS controlled but now some of the settable stuff in MMI overlaps w/ it IIRC.
#86
Found it in the MMI as you suggested. Thanks for your help both you and Jack88.
#89
Can not get the massage function to stay longer than programmed. I get a value error when trying to do so, i can not make it longer nor shorter.
all other coding works but this does not ?
#90
