What's a fair price for a brake job?
My brakes are making noise when slowing down at moderate speeds. Took it to my local indy and was told $1710 for 4 pads and rotors, all OEM. I need to confirm if that was parts and labor or just parts. I was having him check out the car as my warranty ends next month and I wanted to see if there were any other issues with the car. Regardless, first major expense on the D4, is this a fair price? Curious what Audi is charging because if they are close in price I would just have them do it so I at least get a nice loaner...
If you source the parts yourself and pay for labor you should be around a grand at independent shop, in my opinion. OEM is your only option for front rotors but their are plenty of options for the rear as well as pads.
Front Pads: $156
Front Rotors: $491.40 (both)
Rear Pads: $97.50
Rear Rotors: $366.60 (both)
Total parts: $1111.50 + shipping
Keep in mind, that's for the most expensive and largest brakes of that year. The smaller ones run about $870 total in OEM parts. You can always check with a dealer to confirm part numbers or have them match the online price when ordering for your specific car. Audi Silver Spring always did for me if I asked. Here's the online ordering site where I got the prices. It's also worth noting that the front are changed as normal and the rears use VCDS to do the job, realistically taking about an hour's labor total for both sides.
For my A6 I purchased front and rear Zimmerman rotors (prob used by Audi) and OEM pads online for about $480 and my Audi dealer will install them for $550. $1030 all in including the rear wear sensor cable.
oem front rotors for s8 is $600 from the cheapest place online.
anyhow anyone know of any ceramic pads for the s8? seems like a couple brands are out there however no one makes both front and rear...hawk makes fronts and a some cheap company makes rears lol.
these brakes look like brembos...wonder if brembo brake pads for 380mm rotors would work with these
ha...wish the s8 would even come close to that number lol...if i could do front and rear for that price i would do it right now even though i dont need it.
I already have a set of front pads in hand for the S8 in my typical EBC Red Stuff for lower dust and similar to OE feel. The rears are pretty commodity typically; the fronts are the ones that are still harder to find in 400mm. If you want to go a bit off beaten path, Carbotech already lists all their compounds for both front and rear for S8; several of those are ceramic based. From trying some on Mini w/ JCW Brembo type brakes, they were more dust than EBC reds.
Front set up in 400mm is a lot different than 380mm set up for calipers. The rotors are the same quasi two piece design, but not the calipers. Yes, 400mm is basically full on 6 piston Brembo, and then no floating caliper pin stuff with pistons only on inner side. The shape is a little bit different, but they are also almost identical to the 400mm CCB calipers, though CCB's have a further heat insulator at face of pistons. The 380mm is a more typical volume set up--twin pistons, one side only, floating caliper on pins. Pads would probably only be same by coincidence in front, though you can always look at Audi parts slides to confirm.
Also, at least for the 380mm D4 owners, here is a link to a Q5 thread underway currently. SQ5 uses the same 380mm set up Audi borrowed from the D4 parts bin. Likewise, some of the quotes there seem pretty ridiculous to me.
https://www.audiworld.com/forums/q5-...24%24-2916917/
audiusaparts.com that I usually use would cost me $515, plus some shipping but no sales tax--assuming I have correct part #. As usual, cheaper than an ecs for dealer OE if by chance you looked somewhere like that. Also realize that in a dealer job, they are going to want to replace the noise dampener pads behind the brake pads for at least a couple more C bills just for parts set. The DIY'ers and at least some indies are reusing those if removed carefully from old set.
when you go with ebc fronts to they make the matching rears? or do you just go with another brand?
