[HELP] 1992 100CS NON Q radiator compatibility
I need to know if a radiator from a 12/96 A6 2.8 Automatic Quattro, will fit my 1992 100CS 2.8 Manual Trans. NON-Quattro.
Are the compatible?
Thanks.
Are the compatible?
Thanks.
I know the early 1992 production year had different rads. Mine is a very early 92, production date of 7/91 and when I had to replace mine I had to get a rad with the extra heater hose size outlet for the oil cooler. I believe the change was made 4/92. I have a 1993 100cs parts car and it does not have the extra water outlet near the bottom. Hope this helps.
Yep, nailed it. Mine is an early production year.
Would it be possible to get a radiator from a later build and block of the oil coolant fluid?
Any gurus out there know if this would be possible?
Thanks.
Thanks.
mattmondo
Audi 100 / A6 (C4 Platform)
01-04-2012 05:51 PM
Jack in FL
06-01-2003 08:16 PM
