'98 A6 Quattro camber alignment issue...
Old 03-13-2016, 07:30 PM
Trick_A6's Avatar
Default '98 A6 Quattro camber alignment issue...
I recently had to install new tires on my A6 and took it to Sears for an alignment. The passenger side camber was set to -1.3° which was the best the tech could do and is the max specified range.
It appears the bushings are pretty bad (157,000 miles) and my trusted mechanic said I will need to install control arms. I'm not sure at this point if I want to spend the $$$ to install new control arms yet. The car's value is not that much and it's basically a local car for around town these days with an occasional jaunt 150 miles away to our other home.
The steering wheel was pretty off center so I took it back to Sears to have them address that and this time the best the tech could do was -1.4° on the passenger side camber. Everything else alignment wise is as good as can be with nothing even close to being near the specified max range.
Will the -1.4° camber cause any real issues with tire wear with the max being -1.3°?
-OvO-
09-10-2008 05:11 PM
ecgarzone
Mid Atlantic Discussion
11-29-2005 01:43 PM
Avants
10-29-2004 10:22 PM
Quattroleap
08-30-2004 12:35 PM
dougs2.7T
02-26-2004 06:53 PM
Quick Reply: '98 A6 Quattro camber alignment issue...
