Im back
Old 04-03-2009, 09:34 AM
Member
Quattromond's Avatar
Default Im back
So after a long leave from the audi world, I had sold my previous 96 A6 avant quattro and moved on. I got a 97 A6 sedan quattro for dirt cheap. had loads of miles and it didn't have a blow headgasket like stated it needed a t-stat. I sold that and bought a 2002 BMW 325xi and now have that and my brand new old 97 A6 quattro back for $400 cuz the lady didn't want it anymore. So I will be doing some work to it as its running horrible, but with 212k plus miles what's to expect.
So its got a lean code and multiple misfires and no power with a hell of a hesitation when trying to accelerate. Im gona be doing some searching and pokeing around to try and get her back into running condition. I just got a new cam adjuster seal to stop the ticking or see if that helps and ill move on from there.So ill be hopeing to hear from you all again.
Old 04-03-2009, 10:05 AM
Midniteoyl's Avatar
Fuel pressure, filter, pump, dirty injectors.
Good deal..
Old 04-03-2009, 10:18 AM
Member
yea im gona take the injectors out and take a look. I did some searching and I gues I don't have a cam tensioner seal, cuz I don't have a 30v. I told vw that it was a 12v and they still sold me the part so dam they got me for 8 bux.
Old 04-03-2009, 10:20 AM
Member
The fuel filter is new to btw.
Old 04-03-2009, 11:09 AM
Midniteoyl's Avatar
Just out the coil packs and plugs/wires too... But you sound like you knew that
Old 07-28-2014, 02:25 PM
AudiC4HighExplosives's Avatar
My car is doing the same thing. I got a PO1074 code... Too lean, hesitates when accelerating. Please tell me the order of what I should replace first, probably the least expensive things. Like a fuel filter? Thanks in advance!
Old 07-28-2014, 02:45 PM
Rusty Spokes's Avatar
Check all the vacuum hoses..and better still..just plan on changing all of them. New spark plugs..new fuel filter..new air filter and a good once over for air leaks around the injectors and intake..you can use some carb cleaner and spray, with care, at various locations to see if the idle changes with the engine running.
Old 08-01-2014, 07:50 PM
Default Breathing new life into my A6
Great how to video. Changed mine today and saw instant improvement in acceleration and idle. Still laggie though... Found my crankcase breather hose was broken. Tomorrow's project!
TiltedBrimSlim
New Member Welcome Area
02-18-2015 04:47 PM
LaserRedB5S4
Audi 100 / A6 (C4 Platform)
11-28-2007 05:43 PM
jonmarch79
06-30-2005 10:17 AM
Twisted Pair
12
10-01-2002 09:43 AM
imaudi5
42
01-21-2002 01:59 PM
Quick Reply: Im back
