Dash light replacement
#16
All dash lights have gone out in my 100
So one night, I'm leaving work and I go to flip on the headlights/dash lights and the dash lights don't come on. It was not a slow progression, just all at once. I've checked fuses and wires/connections I could get at without taking the cluster out to no avail, so does anyone know of any problem hot spots that I could check first? And to be truthful I have limited electrical skills beyond reading wiring diagrams, and fixing simple problems. Any help would be much appreciated.
#17
Were you have trouble with other electrical accessories, e.g. A/C, radio, headlights, etc., when you turned the ignition on? If so, it could be the ignition switch, which is a common failure. Check the C4 FAQs for fixing this problem.
#18
It seems I have 2 bulbs out- the fuel gauge and right side of speedo are dark and the PRND indicator also. Which bulbs do I need to order? I assume there are no LEDs compatible.
SIXSIGMALARRY
10
12-05-2009 01:32 PM
JRs '89 100
Misc. Models Discussion
09-05-2000 09:20 AM
