So the Audi's frame is bent - AudiWorld Forums
Old 05-27-2008, 02:37 PM   #1
Default So the Audi's frame is bent
from the accident I had a couple of weeks ago. Just found out from my mech that in addition to being smashed, the underbelly is also bent, including the frame. I am debating on getting her fixed. I've already sunk so much into her already (new 02 sensors, tb, wp, serp belt, and so on) and would rather not have that go to waste, but I have heard that once the cars frame is bent, it never drives the same.
Has anyone here experienced a bent frame that's been fixed and recovered? It seems like a waste for all that work to be thrown away, but if the car isn't going to drive the same, I'm not sure if it's worth it.
crusininda944 is offline   Reply With Quote
Old 05-27-2008, 03:21 PM   #2
Default Well... I found out during my engine swap that my A6 took a pretty good hit sometime in the past...
Welded frame rail:
<img src="http://www.boost-instruments.com/v6/DSCN1811.jpg">
And the inside of the LF fender is black, and the bumper is suspiciously new-looking for the mileage, so the only conclusion is the car underwent some major body repair at some point in the past. It drives just fine now -- quite nice in fact. But I'm sure the accident occurred when the car was worth substantially more than it is now.
kday is offline   Reply With Quote
Old 05-27-2008, 03:50 PM   #3
Default If the repair is done on a professional machine...
...they should be able to pull the alignment points back to the proper positions. I wouldn't go with the lowest bidder. Experience and equipment counts on this job.
rmccomiskie is offline   Reply With Quote
Old 05-27-2008, 05:35 PM   #4
Default Good friend of mine had an accident and bent the frame...
he drove a 2000 A4 1.8t with a bent frame and never knew it until he tried to trade it in. It drove very well, even better than his 99' that was never touched and he owned since new. Like stated before, get it done right. I dont know how hard and where you hit but "most" frame shops are honest enough to tell you how bad it is and even show you where.
Best of Luck!
Skribbs2000 is offline   Reply With Quote
Old 05-28-2008, 06:26 PM   #5
Default Aren't these cars unibody??
damaged section would be cut out and replaced ..
Audi Logic is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2012 Q5 Sunroof Frame Leak mjdQ5 Q5/SQ5 MKI (8R) Discussion 20 09-17-2015 05:32 AM
can you Identify this part djjuice A6 / S6 (C5 Platform) Discussion 8 09-03-2015 12:30 PM
My 2006 a4 2.0t is misfiring very rough and it shows 3 codes p0300, p0304 and p310b gregorydouglas89 A4 (B7 Platform) Discussion 18 09-01-2015 11:33 PM
retrofited cruise control getting fault 005481 Defon A6 / S6 (C6 Platform) Discussion 0 08-31-2015 12:38 PM
PRND FAILURE Janryk A4 Cabriolet (B6 Platform) Discussion 0 08-30-2015 03:12 AM
Tags
1994, 944, a3, a4, a5, alignment, audi, bent, cars, drive, fixed, frame, rail, s4, wheel
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
