1995 Audi A6 Base A AFC Model
Old 12-28-2013, 02:24 PM
Earnest Aviless's Avatar
Default 1995 Audi A6 Base A AFC Model
I bought this vehicle and it came only with the main ignition key. I cannot access the trunk using this key~how in the world do I get in without haveing to go through the glove compartment? Is there a key for just the trunk?
Old 01-08-2014, 07:20 PM
audi95's Avatar
Should be the same key, unless the ignition had been changed. You should be able to use the power lock button to unlock, then push button on trunk and lift.
Old 05-19-2014, 10:20 AM
wynot's Avatar
Does your ignition key open your doors? Like the above poster, a fair amount of people have an ignition lock replacement and just get a keyed lock from the dealer, but not the lock keyed to the car's other locks. Heaven help you if the remote gets unsynced, because you need the door locked by the key to resync it.
SJGQ5
Q5/SQ5 MKI (8R) Discussion
08-11-2022 06:51 AM
bballfreak
9
04-14-2019 06:59 PM
lmariorod
10-26-2017 11:39 AM
gruvenparts.com
10-11-2016 04:47 AM
hardipk5
10-02-2015 08:32 PM
Quick Reply: 1995 Audi A6 Base A AFC Model
